FixYa.com
Tags:
Gateway Belkin 54g Wireless DSL/Cable Router
Cannot connect to my Belkin54g router!
posted by LightLau on May 30, 2008
l use the 192.168.2.1 to log on my router but it cannot log in the router. Why?
l have do some settings on the router before but l not sure what l did. Anyone can help...Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 31, 2008
FixYa! (100)
jeffpankow
Rank:Master Master
Rating: 95%, 15 votes
Your router can be reset to effectively "reboot" it, or restored to the factory defaults to clear any erroneous settings that might have been set. Your router must be powered up for this to work.
To reset the router, press and release the reset button on the back of your router. This will reboot the router and might allow normal functioning.
If this does not fix your problem, press the reset button for at least 10 seconds. Your router should then be back to factory settings and hopefully back in your control. You must now go through the setup process to get it back to a useful state.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Routers problems?
Routers
set up router
help 830-223-7039 Answer This...
Routers
Fritz!BOX fon WLAN 7170
Hallo, ich habe diese Box... Answer This...
Routers
connecting a laptop to belkin...
I am having problems connecting... Answer This...
Routers
broadband connection type using...
I am uncertain which connection... Answer This...
Gateway Belkin 54g Wireless DSL/Cable Router...
i have tried to install
i have tried to install router... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
