Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Garage door won't close unless I hold down the wall button until it is fully closed. Checked the L.E.D light at motor and it flashes 2 times in about 8 seconds. Sensor with amber light is on, other does not light.
  • 504 Answers
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
Posted on Oct 22, 2010
My Chamberlain 41A5389-1B 1/2HP door opener will only close via the wall push button when it is held down until door is fully closed. Will not close with remote, when using the remote it will start to...
Have you checked the tracks on both sides? If the door closes when you hold the wall button there may be an obstruction or a bad guide. This could exert enough resistance to make it stop and reverse. Holding the wall button allows it to keep going past the problem.
Apr 28, 2017 | Sears Craftsman LiftMaster Chamberlain...
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, with out hold down on button.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Sep 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
May 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
1,793 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
