Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husqvarna 51 idle seems to struggle, runs OK when I throttle then chokes and dies out as soon as the throttle is released. What can I do?
    Problem Solver:
  • 4 Answers
Will it start right back up after it dies? you could use a small screwdriver and turn the idle screw in a little to raise the idle speed that should fix it.
Posted on Oct 12, 2010
I have a Husqvarna 142 chainsaw. The saw will idle, however when I depress the throttle the saw chokes down a dies.
What condition is your spark plug in?Is your filter clean?Is your gas-oil mixture correct? Is your gas fresh?Is your brake releasing?Is the blade and chain on correct?
Nov 21, 2016 | Husqvarna Garden
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
Strimmer will not run on full throttle.When choke engaged will idle fine,but as soon as I release the choke it dies.It has fresh fuel mixed correctly.There are no obstructions such as grass in the...
This condition sounds like a plugged main get. Take the carb off, and clean it out, run spray carb cleaner though all passageways, and test it again. No need to focus on the idle circuit.
Apr 15, 2011 | Garden
How to adust carb on husy 51 saw will run a bit than bog down
there is two plastic adjust jets with a little grove in it, that is to adjust the airflow and petrol injection, one is red and one is white (normally) it is located next to the air-cleaner near the bottom of the carb. what you should do is get a long enough screwdriver (flat that will fit in that grooves) start the machine ref it and adjust the white jet to your right (very slowly) and see if it is running after releasing of the throttle, if it dies start again ref and adjust the red one to your left(very slowly) and leave the throttle and see if it idles, if not try step 1 and 2 again until it idles. those adjust jets has a kind of sharp point, those 2 sharp points must not cross each other and remember if you start you must undo the choke immediately, otherwise it going to die in any case, maybe that is your problem
Dec 12, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Runs first 30+ sec then bogs out/dies when throttle pressed
If still under warranty have it serviced (authorized dealer not Joe's lawn mower). There should not be a fee (paid by Husqvarna). There have been carburetor problems. If you adjust it your warranty will likely be void; Joe's small engine service just as likely to void any warranty. Are you using a fresh 40:1 fuel oil mix. The will not start with choke set is normal. Start procedure in your OM says listen for sputter and disengage choke. Almost all new saws have similar start procedure.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Want start
Read the warm start procedure from the operators manual.
1. Pull choke (sets fast idle)
2. Push in choke (fast idle retained)
3. Make sure ignition is on, pull (usually once on my saw)
4. Advance throttle slightly to release fast idle.
I made the mistake ONCE of not setting the fast idle. My shoulder gets sore thinking about it. HTH
Lou
Sep 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I can't find the adjustment for the fuel mixture on my chainsaw, it is a husqvarna 61. i see the throttle adjustment but that is not helping, i have to keep the choke about 1/2 way out in order to keep it...
It is running lean. Continued operation like that will cause it to fail. Spend $40 for a tune up by your friendly neighborhood chainsaw seller/mechanic. If you ask nice they will show the location of the carburetor adjustments (3 normally). HTH
Lou
Sep 16, 2009 | Husqvarna Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
393 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
