If the wires are just cut. Splice each wire back together. Other wise look at your tsat and check your wire there; mark your color code(wire color) as they are attached R,G,Y,O,ETC. If you have a heat pump there will be at least four wires and if it is not a heat pump it will have a minimum of two wires. Open your condensor and find the wiring diagram. Compare your colors from the tstat. It will be listed as the letter just as your tstat. Connect accordingly.
