Question about Ovens
Garland Master 410 Commercial Convection Electric Oven
I need to know how to convert a Garland Master Convection oven from 460V to 240 or 208V. Please advise.
SOURCE: kitchenaid KEBC177 electric convection oven will not heat
This is a design flaw in the Kitchenaid convection ovens. I can help fix this problem if you have a built in oven (I don't know if the parts are located in the same place for stand alone ovens). First it is not a FUSE that has blown rather it is the thermostat in the rear of the oven. (Part #4452223) This small part cost about $37 US and after shipping it will cost you about $47. I tried to get an estimate from an electrician as to what they would charge for the part and to come out and fix the oven an the price was about $90 for the part and anywhere between $100 and $170 more for the service call + repair! After a day of frustration I decided to tackle the problem myself.
The very first thing you must do is shut off the circuit breaker to the oven and put a very large sign on the panel that reads DO NOT TOUCH! That is 220 volts to that oven and while most panels have just the oven ont circuit you dont want anyone reactivating that circuit by mistake!
The next part requires a little work. Find the side panel screws (usually located in the oven door) and remove the two panel flanges that cover the 2 or 4 mounting screws that keep the oven in the wall. Now go underneath the oven and find the power junction box, take off the cover and disconnect the wires that run from the oven. Remember which goes where. Next remove the little nut that holds the electical conduit cable to the junction box then loosen the wires. Once this is done you can now slide the oven out and get to the thermostat.
This part requires a little elbow grease. Find a platform or table that fits just under where the stove will slide out and slide the oven on top of the table or whatever for support. In the back of the oven there will be a sheet metal panel that covers the thermostat and other wires, remove the 5 or 6 screws that hold this panel on and put the panel aside. Almost in the middle of the oven's back you will see a little black device with two wires running out of it (one red the other white or yellow). It will have the part number on its front, remove the wire and notice that the thermostat is half red and half white (remember this for the new part will have the same markings) the red wire goes onto the lead coming from the red markings. When you have the new part simply put the new one in (remember: the red side to the red wire), attach it to the back of the oven, replace the sheet metal cover and slide the oven back into place securing it with the screws. Viola! you are done! Turn on the power and then test the oven (I used the broil setting to warm it up then switch to a temperature setting). The entire process took me about an hour and I am NOT a handyman!
For about $50 and a little work you will save yourself from $150 to $250. Not to mention the repairmen won't have a clue as to what the problem is or who will attempt to sell you a new front panel or perform other unnecessary work.
Posted on Dec 09, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
  • 125 Answers
SOURCE: turbo chef oven F6 ec code
Hello. There is a temperature sensor built into the control board, and the temp in that area, is getting too hot. On the back of the unit, right top, there is a cooling fan that comes on at a certain temperature, if the intake is clogged, you will get this error, clean the intake. Inside the unit may be so dirty, it may require cleaning as well. The fan itself could be bad, and does not run, then it will need replacement.
Hope that helps, and thank you.
Posted on Feb 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid Superba electric convection oven not preheating right
Your temperature sensor is failing. Replace the temp sensor.
Posted on Jul 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a Thermador electric
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, I`d start by looking for an overtemp cut-out tripped. Did this problem start following a self clean cycle ?
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If you feel capable of repairing this yourself I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can.
macmarkus :)
Posted on Aug 05, 2010
I NEED A PARTS MANUAL FOR A GARLAND CONVECTION OVEN MOD#ECO-G-10-E I HOPE YOU CAN HELP ME. E-MAIL ncf4031@tampabay.rr.com thank...
Seems to me that the easiest and quickest way would be to email or call Garland, or go online and get a toll free number. . .
Jan 18, 2018 | Garland Ovens
Oven cooks too fast and burns the food
My electric oven, Garland master 200 only reach a maximum of 250* and I only saw 1 of 3 elements turn red
Dec 14, 2012 | Garland Convection Oven - MCO-NAT Gas
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
hi,
thank you,
Feb 19, 2009 | Thermador C272 Electric Double Oven
GARLAND CONVEC. OVEN - CONVEC. NOT RUNNING
it sounds to me like the door switch is not making. if you take off the bottom panel the switch is to your rightat the bottom. make sure that you kil power first brfore you remove the panet.
Dec 22, 2008 | Garland Convection Oven - MCO-NAT Gas
Ovens Logo
374 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
