Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
I HAVE sHARP tv MODEL 14R2 ONLY CHANNEL KIT IS DEFECTED PLEASE SUGGEST ME CHANNEL nOS.
I have sharp tv lost password how to unlock ?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience. Unlock procedure to many popular brand TVs are given.
Aug 10, 2014 | Sharp Televison & Video
Need factory password for sharp tv model 14r2 mk5g
Have you tried 0000 or 1234.?
hope this helps
Apr 12, 2011 | Televison & Video
Unlock sharp 14R2 Television. TV shows "please input password" when switch on.
Try to hold down the display key for 4 seconds. I have got similar problems and will check today if it works.
Jun 09, 2010 | Sharp Televison & Video
Trying to connect Sharp VCA310X VCR to TEAC TV CTM5140; am only getting blue screen with audio; no picture! Have tried every possible combo with the AV cables (red, white, yellow).
I would suggest trying to change the channel, either on the tv or the vcr. Sometimes, if the channel is one off, you will get sound but not a picture. On the back of the vcr, there SHOULD be a switch to change it to either channel 3 or channel 4. You must match this up with the channel your tv is set for. I hope this helps, but if not, I hope you can get it figured out soon. Good luck! Der Strom
Apr 13, 2010 | Sharp Televison & Video
RCA TV changes channel and volume, and shuts off by itself.
ok its not a cap problem.. memory ic problem...u have to replace memory ic the nos are i think 24c16 or24c08
u have to buy the memory by giving ur model no of the tv
Mar 06, 2010 | RCA 27V520T 27" TV
Figuring out the TV channels for Comcast using the Sharp remote
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
Jan 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
My Sharp Friendly series 20V tv has no sound
change the speaker of your tv,maybe it's defected
Oct 06, 2008 | Sharp 32C-240 32" TV
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp 20" LC-20B4U-SM
I cannot say pariculary for this model, but on some models of TV sets, if the channels are not programed as part of the channel list, they are muted.
Turn on the TV, and perform the channel auto setup.
Jerry G.
Nov 20, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
