Question about Lands Phones
How do you set the contrast on the nexxtech 4313346 phone ?
Contrast has gone down. i want to increase my nokia e65 display contrast
1.go to setting 2.select (phone setting) 3.select (color contrast) 4.adjust the level onward or backward then its up to you if the color is ok. But if not,then adjust it again until it feels you comfortable...
Aug 08, 2011 | Cell Phones
I try to set my nexxtech watch . I can't find the way to set the clock ... could you advice me how ?
Without knowing which model you have, this should help.
Go to the following link and near the bottom of the page, choose Category - Watches, Brand - Nexxtech and then choose the Model watch that you have. It will give you the option to download/view the manual to set the time.
http://www.thesource.ca/estore/exclusive.aspx?language=en-CA&category=Watches&brand=NEXXTECH
Mar 14, 2011 | Watches
I have a big button nexxtech phone 4313348 and no manual Can you direct me to a copy
Try the following direct URL to the PDF: http://www.mts.ca/file_source/mts.ca/Static_Files/Raw_PDF/NexXTechUsermanual.pdf . Googling the phone manufacturer and model will get the same link listed as NexXTech/PurTek User Manual.
I hope this helps.
Dec 09, 2010 | NexxTech 4318570 Corded Phone
How to set up a Nexxtech wired router?
Hi, manny_khera This could be a bit complicated...or not? First we'd need to know the make and model of your comcast modem as it may be a "modem/router" if so, it will need to be set to bride mode before your new router can work properly - to avoid "double natting" (both devices attemting to preform the same fucntion - network address translation.)
Jun 06, 2009 | NexxTech 4-Port Ethernet Broadband Router...
Avaya settings
Click on options which has a tick on the button. You would find the option contrast control.
May 27, 2009 | Lands Phones
SCREEN NOT DISPLAYING NUMBERS
If you haven't already tried it, unplug the phone, press a couple of buttons, then plug it back in so it resets. If the boxes still appear, try adjusting the display contrast. Press Feature-*-7 to get to contrast setting and then press 6 or 7 to set mid-range contrast.
Mar 30, 2009 | Nortel Meridian M7208 Corded Phone
NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
Problem setting up Enclosure
Please check if your jamper of the hardrive must be set to primary settings. Or possible your usb connector having lost contact problem.
Hope this will be helpful to you.
Oct 26, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Lands Phones Logo
56 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
