Question about Reliance & Pilot Assembly for Natural Gas Water Heater
The pilot light goes out randomly. Why? Can the flame size be increased? I don't know that that is the problem but am wondering if there is some adjustment that can be made to keep the flame burning. This is a Model 606. Closed chamber. I have just replaced my old water heater with this unit, which has not been used before.
    New Friend:
  • 107 Answers
I'm not aware of flame adjustment. However, if it has a thermocouple make sure it is tight in the gas valve or the thermocouple may be bad. The flame heats the thermocople and this generates a milivolt charge that has an electro-magnetic force that holds the pilot valve open. Also check for a blocked flue.
Posted on Oct 10, 2010
The pilot on our hot water heater randomly goes out for no reason. What could cause this? We've replaced all the parts service guys have suggested and nothing has changed.
pilot lights go out from --not enough pressure or wind drafts than can get to the area blowing them out
check for missing shrouds to protect the flame
Nov 07, 2015 | Water Water Heaters
How do I make the flame of my water heater pilot bigger, it seems to little and goes out every day. I have installed a new thermo coupling but the pilot flame is small. Is there a place to increase th
If the pilot is going out, it may be from lack of combustion air intake. Make sure you have fresh air in the water heater room...one within 18 inches from the ceiling, & one within 18 inches from the floor. The size of the openings is determined by the BTU's of the water heater.
Dec 13, 2014 | Rheem Richmond 40 Gal Natural Gas 12 Year...
My 606 reliance gas water heater run for 5min and pilot goes out
If the pilot will light and stay lit, then ECO is not tripped, and thermocouple is probably good.
If ECO is tripped, then pilot will have no gas.
Usually if thermocouple is bad or installed incorrectly, the pilot goes out immediately after releasing the pilot knob during lighting.
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
First thing is to clean water heater air intake and get more fresh air to the water heater and see if that solves problem. Combustion of hydrocarbon requires oxygen that must be pulled into the water heater from surrounding rooms. If water heater is closed off, or located in hot attic that is not correctly vented, or house is tightly sealed, or air intake is clogged, then there is not enough oxygen to support combustion.
Next thing to check is color and size of pilot flame.
If color of flame is NOT clear blue, or if flame is weak, then that says the pilot orifice and burner tubes and burner should be removed and cleaned, along with cleaning combustion chamber.
Additional suspects include combination of things, including: , bad gas control valve, low gas pressure, air in gas line, water dripping down vent and putting out pilot, reverse air flow or backdraft down the vent that blows out pilot, damaged burner parts because of exposure to trace chemicals such as bleach and wax.
Open following link to see various images and read resources.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
Sep 21, 2011 | Water Heaters
My White Rodgers Gas Valve 37C72U keeps going out. It burns well for ten to twenty minutes and then just shuts off. It lights first press but goes out again after the above time. All flames appear good....
have you replaced the thermocouple connected to the gas valve?if they get bad they will shut off gas flow,and no you cannot adjust the pilot flame size which is controlled by the valve also
Mar 27, 2011 | Water Heaters
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Reliance & Pilot Assembly for Natural Gas Water Heater  Logo
224 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
