Question about Razor MX500 Dirt Rocket
Rear wheel does not turn - Razor MX500 Dirt Rocket
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
Posted on Nov 03, 2010
  • Mary Morgan May 12, 2013
    What kind of shop would l bring this to for repair?
Why are my rear wheels locked up?
Seems like your emergency brake is engaged or stuck engaged
Dec 13, 2015 | Cars & Trucks
Why do Both my back wheels turn in opposite directions
Hi Anthony. This is a reaction called "Torque" Commonly, most rear wheeled vehicles have what is called "Limited-Slip Differential" What happens is, as the vehicle makes a turn, the inside rear wheel rotates slightly slower than the rear wheel on the outside of the turn. This ensures even power distribution to the rear wheels from the transmission. If you have a "Positive Traction" (Posi) rear wheel drive, then when you accelerate, both wheels turn at the exact same rotational time. The consequence of this is, when you turn, you will hear a rear tire squeal on the pavement. There is also the "Semi-Posi" that acts like an Limited-Slip, until you apply power. Then the rear wheels turn at the same rotation, but only under power. To experience what it would be like if all wheels turned the same direction at the same time, find someone with a 4 wheel drive (4x4) with manual hubs, and on pavement put it in 4 low and try to turn. 2 of the tires will squeal on the pavement, and you will notice it will slow you down very quickly during a turn. I hope this gives you the info you wanted. ^^
Aug 17, 2015 | Cars & Trucks
What causes rear wheels not to engage whether in 2 or 4 whhel drive? Front ones only turn when in 4x4.
If the shaft is powering out to rear end then internal on rear possibly broken differential. If no power from case to rear then broken in case.
May 31, 2015 | Cars & Trucks
Turn whhel real sharp on 2005 ford explorer left rear wheel wants to lockundefined
If you have four wheel drive, turning the wheels sharply at a slow speed when in 4X4 mode can result in a wheel binding. The other possibilities are low lubricant in the rear differential, wrong lubricant in the rear differential if it has been replaced, or a bad differential.
Oct 05, 2014 | 2005 Ford Explorer XLT
Why every time when I turn the steering wheel the rear differential starts to lock and it shakes?
Do you have the vehicle in 4 wheel drive? 4 wheel drive is only meant for slippery conditions. It will act exactly as you describe if on dry surfaces.
Aug 22, 2014 | 2002 GMC Yukon Denali
What cause rear brake to stick?
Possible out of adjustment, bad proportioning valve, bad springs on brake shoes, shoes out of alignment, leaking wheel cylinder. Good luck
Apr 10, 2017 | 1990 Chevrolet C1500
I have a jazzy 1107 power wheel chair the back wheels are leaned outward i dont think the back wheels should be leaned outward i think this is what is causing me not be able to be able to turn properly....
Have some one check out that the section has not become loose or broken. IF the wheel rubbers are damaged then you will have trouble regardless of what you do. I consider it paramount that the chair is in top condition for your needs. Have the manufacturer's service agent fix it for you.
Sep 22, 2013 | Health & Beauty
Rear scraping sound, Also when placed on lift and in gear (all wheel drive) the rear left wheel does not spin
Take it in for proper diagnosis - that's not supposed to happen in an 'ALL WHEEL DRIVE' - all WHEELS ARE SUPPOSED TO TURN.
May 20, 2009 | 2004 Hyundai Santa Fe
The rear went out in my SUV and I need to know the gear ratio. I have another rear but need to know if it will work.
Hold one wheel. mark the other wheel. Turn the unlocked wheel two complete revolutions. Count the number of turns the yoke make in two revolutions of the unlocked wheel. 3 1/2 turns= 3.42 3 3/4 turns 3.73 and so on
May 15, 2009 | 2000 GMC Jimmy
Possible rear wheel problem
if both rear wheels are off the ground, yes. note that they turn in opposite directions.
Jan 03, 2009 | 2004 Chevrolet TrailBlazer
Razor MX500 Dirt Rocket Logo
787 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
 steve
steve
Are you a Razor Cycling Expert? Answer questions, earn points and help others
