Question about Tsunami Lite Wave Capacitor 2.0-farad with Blue LCD Meter
I have a tsunami light wave 5 fared capacitor running 2 kicker amplifiers running around 2000 watts total and its all been working great for about 2 or 3 years until just lately. it works fine when the volume is extremely low on the amps but as soon as the volume is turned up enough where it draws one or two amps of power the amplifiers cut out and i take a voltage reading on the capacitor and its only giving me 8.5 volts at the output instead of the normal 12. the battery is fully charged, if i remove the capicitor and hook everything straight up to the battery everything works fine. what is wrong with it?
    Top Expert:
  • Tsunami Master
  • 44,045 Answers
The capacitor may be failing.
Posted on Apr 14, 2017
  • 9 Answers
SOURCE: 3 kicker CVR12 Car Subwoofer to a amp tsunami 1100
The only way you can do this is if the amp has a min of three channels. you will need to bridge each speaker seperately. With that much power, attempting to bridge all three subs together will cause the amp to over heat and possibly blow. email me the specs of the amp and subs and i will give you the best advise quigley1313@yahoo.com
Posted on Feb 24, 2009
djmaximus_87
  • 26 Answers
SOURCE: capacitor shuts off
HI DUDE UR CAR BAT NEED TO B CHANGE PLUS UR ALTERNATOR IS GOING TO FAIL SOON ... THATS ALL ... IF U ARE USING NOW IT MAYBE COZ LOTS OF PROBLEM TO CAPICATOR
Posted on Jun 23, 2009
Boole5555
  • 160 Answers
SOURCE: kicker subs hook up problems
Connect one to each channel, for the best sound.
Posted on Jan 05, 2010
Testimonial: "thanks"
  • 24 Answers
SOURCE: Why is my Kicker 08zx650.4 amp turning off in my 98 Deville??
ive been hearing alot of this going on yes you had youre system proffesionaly installed but youre amp is pushing at all its got it must be pushing at 1ohms capacity loud but what you dont realize is that.. do ur home work first some amps say they can handle the power but if you read carefully it would read not stable look up amp on the net before buyin review them first ...but evrything youve got is correct its youre amp it wont burn out but you wont get continous power to ur spkrs ..i recomend installing one amp on each spkr same brand if you prefer in keeping it with a crossover if you dont have one that way they wont over heat and cutt off and you will use less power and get more bass...
Posted on Feb 24, 2010
  • 173 Answers
SOURCE: digital audio dhc 2754
no thay need 1000 rms each i would go with a hifonics bxi2010d amp from vminnovations.com for around $300
Posted on Apr 03, 2010
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
Capacitor shuts off
Apr 05, 2009 | Kicker DX700 Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
What power cap do i need for my car audio
I would go with a 4 FARAT capacitor then you know your amp won't be dimming your lights or clipping your amplifier signal.
I would actually buy the kinetic capacitor from www.onlinecarstereo.com they rated at being 100 1 farat capacitors. Great buy since it's on sale for $200 with added shipping.. Otherwise the 4 farat is needed.
Here's the link: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20378
Feb 09, 2009 | Pyle PLA2200 Car Audio Amplifier
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker cvr and ameican legacy 2000 watt monoblock amp. I just need to know if this would hit hard? n if der is anything i need so i wunt damage my 2006 malibu at the same time
The amp, i am not so familiar with, so do your homework...
You want to pay attention to sound quality specs such as signal to noise ratio (the higher the better, like around 100 ) and THD (total harmonic distortion, the lower the better, like between .1% and .001%) If your amp is putting out 2000 watts at a high distortion level such as 1%, you wont be too happy with the quality and you may blow your sub before ever approaching the full 2000 watts.
As fara as your car goes, a heavy duty capacitor would well placed between the battery and the amp, and upgrading the alternator may be considered. If not, you are looking at substantially shortening the life of both your battery and present alternator.
Feb 26, 2008 | Car Audio & Video
Help please
Check your power cable, for bad connections.
Make sure voltage dont drop below 10.8v.
Nov 30, 2007 | Kicker IX404 Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Tsunami Lite Wave Capacitor 2.0-farad with Blue LCD Meter Logo
69 people viewed this question
Top Tsunami Car Audio & Video Experts
xxxxxx xxx
Are you a Tsunami Car Audio and Video Expert? Answer questions, earn points and help others
