Question about Sennheiser Audio Players & Recorders
The left headphone of my HDR 110 (wireless) does not pick up the input. New batteries, tuning adjustment,do not help.
  • cpr609 Oct 09, 2010
    Of course I do not have the technological knowledge or ability to follow your, in all probability, very good advice. Seeking further local advice seems hopeless but I thank you
  • Sennheiser Master
  • 17,130 Answers
First of all if the right side is working the wireless is working alright and the fault is in the processing section, the left audio preamplifier , the left side power amplifier and the left side earpiece.
So you might have to test with a audio signal to confirm from the preamplifier, the low-power amplifier driver for the earpiece and the earpiece.
Once this is confirmed the focus can be the wireless section, possible fault in the receiving section.
The use a a multimeter to check and knowledge of electronic circuits is necessary to check around this section. Please check and respond.
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Oct 09, 2010
  • emmet1 Oct 27, 2010
    I am in a similar circumstance, but I have some functionality from the left speaker.
    Messing around with them for a while I've found that the left speaker only works above a certain volume level on the headset.
    However, this is quite high, so I have to turn the input level down on the ipod/computer etc.
    BUT, the headphones require a certain level of an input or else they auto standby, and if I want to listen to a CD at a comfortable level, it will shut off every 10 mins and I'll get a huge amount of static in the headphones.
    Any idea what I could do to fix this? Or what sounds broken on the headphones?
    President:
  • 2,777 Answers
It sounds like the left channel has probably failed. Have you tried multiple sources and have the same result? Are you sure these are no longer under warranty?
Let me know and I can help,
Tim
Posted on Oct 10, 2010
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
Till yesterday Seinnheiser rs 110 worked fine when i switched it today only one speaker is working i.e is right speaker.I thought batteries were weak then i recharged but have the same problem.When i tried...
  • The wiring has disconnected inside your headphones. They will not work unless you have someone re-wire the headphones for you. This happens after time with most headphones.
  • Please reply if you have any more questions. Good Luck!
Jul 07, 2011 | Sennheiser RS 110 Consumer Headphones
How do I charge batteries?
The headphones will automatically charge wirelessly when placed in the cradle that should have come with the package. To make sure the headphones are placed correctly, a red light should illuminate letting you know they are being charged and are properly placed.
May 03, 2011 | Sennheiser HDR 120 Consumer Headphones
I need replacement ear cushions for sennheiser wireless headphone RS 110 (HDR 110) or some equivalent air cushions that would fit into the RS 110. Thanks
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
Feb 16, 2011 | Sennheiser RS 110 Consumer Headphones
Sennheiser hdr 120 headphones no longer hold a charge. where are the batteries in the headset?
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Dec 27, 2009 | Sennheiser HDR 120 Consumer Headphones
Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Dec 24, 2008 | Sennheiser HDR-45 Consumer Headphones
On/Off not lit when plugged in
There is help for this in the user manual. Possible solutions I would try:
1. Make sure your source sound (TV, amp etc) is up high enough - if the sound is too low the headphones won't detect a signal.
2. Try changing the channel (the switch on the bottom left of the cradle base) and pressing the "Tune" button on your headphones. Try all three positions, pressing "Tune" at least 3 times in each position.
3. Take out batteries & turn off base, leave for 30 secs, reassamble and try step 2 again.
Should all work ok. I've been using mine for over a year and they're great!
Feb 06, 2008 | Sennheiser HDR 130 Consumer Headphones
1,237 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
