Question about Bugaboo Cameleon Jogger
Our brake on a Bugaboo Comeleon will not stay locked. Mechanically it works; just will not stay in place.
I had this exact problem. If I held the lever up, the wheels were locked. So I decided to add a small support that would prop the lever up. I went to the hardware store and bought a package of small eye-screws. I pried open the eye of one of the screws. Then I drilled a hole at the end of the lever, just large enough for me to insert the opened end of the eye. Then I fashioned a support out of plastic (I used InstaMorph, but you could just as easily use a small piece of wood). I screwed the eye-screw into one end of the support, and then rounded the other end so it would ride smoothly on the aluminum rail to which the brake lever is mounted. I drilled a hole at that end of the support to add a cable tie so that the support wouldn't flop around when not in use. It was a lot more fun, and quicker, than dealing with customer support to beg for a replacement part that would probably just break again.
Posted on May 12, 2012
  • 419 Answers
This sounds like the mechanism within the brake (white brake on the handle bar) has broken inside. I would suggest that you contact www.bugaboo.com who generally will give the parts for this repair free.
Hope this helps.
Posted on Oct 13, 2010
One wheel doesnt seem to brake when i put the lever on. it slips and makes a rattle sound. the other side catches on the wheel no problem
This is a common problem with the bugaboo's The brakes use a toothed brake shoe to fit in to a toothed inner rim, What happens is one shoe seems to alway fit into the toothed rim but while the other side always hits the top of the teeth causing the shoes and connecting rod to twist. Eventually you get the problem you describe. The brakes shoes are interconnected by an aluminum rod. The shoes have two splines that fit into slots in the rod and a phillips screw to lock them in. First try taking the back wheels off and getting a strong man to hold the shoe that doest lock while pulling the one that does back in to alignment. This quite often works. If the twist is to much I remove one shoe cut off the splines turn the shoe to align with the other shoe then drill a new hole for the locking screw.
May 22, 2011 | Bugaboo 'Cameleon' Stroller
Bugaboo bee - handle lock not working
it should be under warranty and you should take it back where you bought it from, and they should send it back to bugaboo for a free repair check my site www.buggypitstop.co.uk
Jan 17, 2010 | Bugaboo Bee Umbrella Stroller
Bugaboo bee- one of the sides on the handlebar stopped locking in place (clip doesn't stay closed). It makes it akward to push. bugaboo won't issue replacement part since I bought off craigslist. Help,...
It should be cover under warranty so take it back from where you bought it and ask them to send it back to Bugaboo to have it fixed free of charge. Visit me at www.buggypitstop.co.uk if you need any more advise
Oct 09, 2009 | Bugaboo Bee - Yellow Umbrella Stroller
My bugaboo cameleon's break no longer works. It
There are two ways of solving this. You can either contact the retailer where this was purchased for repair under warranty (if this was of course a fault and under two years old) or you can contact Bugaboo for a replacement brake assembly kit. This is very straight-forward to replace yourself.
www.bugaboo.com - if you go via Bugaboo themselves, they will require your purchase information, colour, serial number etc.
I hope this helps.
Sep 01, 2009 | Bugaboo Cameleon Jogger
Hi I cannot get the handbrake lever to stay on it pushes forward,the wheels are braked but is poops back as soon as I let go can I fix it?
Check for solutions under the heading brake...I had the same issue and followed some solution to take apart the brake handle and it totally worked. (I'm not handy remotely but was able to complete the task in less than 10 minutes).
Good luck.
It sounds like you are having the problem I had...look for the solution that tells you to take the 2 screws out of the side of the lock handle.
Aug 11, 2009 | Bugaboo Cameleon Jogger
The plastic gear inside that locks the brake handle into place of my Bugaboo Cameleon disintegrated. Where can I find the part?
If you contact www.bugaboo.com they will happily sell the complete break assembly to you. This is easy and quick to fit and should resolve your issue.
I hope this helps.
Aug 02, 2009 | Bugaboo Cameleon Jogger
Bugaboo chassie
HIYA... THE CHASSIS STAYS FILMSY AND UNSECURE UNTIL THE SEAT UNIT OR CARRYCOT UNIT IS ATTACHED, THEN ITS LOCKED INTO PLACE AND SECURE :)
IT ISNT A FAULT, THIS IS JUST HOW ITS MEANT TO BE
HOPE THIS HELPS X
Mar 13, 2009 | Bugaboo Frog - Black Stroller
The lock on the brakes of my bugaboo cameleon doesn't work.
I just repaired my Bugaboo Chameleon brake. If the white brake lever doesn't "lock" i.e stays in its forward position, locking the brake you need to disassemble the brake handle housing. Open the black plastic cover by unscrewing the two screws. The handle should come off with a little tweaking. Remove the brake wire. The "button" where you are supposed to release the brake is actually a sort of cogwheel that stops the lever from springing back. Sometimes the cogwheel gets too pushed in the handle. You can tell if it has done so by observing the 8 small grooves that are out of place. Simply take a small flat object like a flat screwdriver and pry the button out. It should pop out as it is spring loaded. Now put it back in its position but TURN IT so it fit in the grooves. Put it back in the black handle, by reversing the disassembly process. Easy!
Best Regards,Fred, Stockholm, Sweden(Sorry about the English, hope you understand)
Aug 17, 2008 | Bugaboo Cameleon Jogger
Bugaboo brake pad is not aligned with wheel
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Mar 29, 2008 | Bugaboo Cameleon Jogger
Bugaboo Frog Stroller (Folds on it's own)
Don't worry, this is normal. Once you lock the seat into place, the front bar stays put, even if you hop a curb.
Mar 23, 2008 | Bugaboo Baby Gear
Bugaboo Cameleon Jogger Logo
340 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
