I have a Westinghouse Beyond Icebox. Normally, it works just great. However, recently it just stopped working. There is a orange light in the back that is steady. It won't turn on at all. Suggestions?
  • 21 Answers
I had the same problem with my FS04 unit (under the cabinet, flip screen). Amber light was on and humming sound comming from speakers. Motherboard had to be repaired by ICEBOX dealer that sold me my unit.
Their website is www.lordantech.com
Posted on Oct 19, 2010
I have recently purchased the z323 speakers and from the first day i have the same problem It works great but every few hours it suddenly stops working amd the power light turns a paler sade of orange I...
Very strange fault indeed; you reports here. There is nothing more to check. See the power output plug at your home. If it has any fault, that is, if it do not fit with the power plug the device you have; this kind of fault can occur due to loose power connection. Gopakumar Gopalan Google
Feb 23, 2014 | Audio Players & Recorders
LVM-37w1 after 5 minutes of viewing, picture and sound go off. Blue power light turns orange. attempts to turn on TV are unsuccessful. Blue light immediately turns orange.
I saw this fix posted on another blog by a fellow named Patrick. I tried it today and it it worked. It fixed my Westinghouse lvm-37w1. Basically disassemble the back of the TV (removing all the screws on the edges and middle). Remove screws holding bottom speaker and stand. There are 2 chrome rods extending down. There are small screws inside holding them on. You can turn the rods and unscrew the screws but need a small screw driver to put them back on. Remove the black cover on the back. remove the plates on the lower middle section. You will expose a printed circuit card. unplug wires and unscrew 4 screws holding it in. Remove it, turn it upside down and inspect the solder joints near the lower middle (especially under the gray relay on the other side). I found 4 solder joints that were cracked. Resolder the larger solder joints that are cracked or look bad (small solder joints are too delicate). Put it back to gether and it should work now. Mine works great. No more black screen with no sound.12_2_2011_5_11_21_am.jpg
Sep 29, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
My Icebox computer will not start up properly. When I turn the power on, it simply hums like an old television with no signal.
Hello,if your computer is old and the noise is low frequency but very disturbing and sometimes gets louder and then lows then is your power supply and you must change it.If the noise is more high pitch and it doesn't change frequency then should be the graphic card.If its like scratching noise is the hard drive.You must figure out exactly where the noise is coming from before replace anything
Feb 03, 2010 | IceBox (HL1214) PC Desktop
Westinghouse Icebox has a Orange Indicator light and a static hum. I have not used the ICEBOX in almost a year, as I was walking by I noticed the Red light Flashing so I unplugged and plugged back in. ...
I had the same problem with my unit. Amber light was on and humming sound comming from speakers. Motherboard had to be repaired by ICEBOX dealer that sold me my unit. Their website is www.lordantech.com
Jan 31, 2010 | Televison & Video
Moniter just stopped working. when you power it up
johnharold3, You didn't say, but I hope it's coverd by a warranty or some kind of service plan. If westinghouse can't or won't help you out, then get back here on fixya and someone will give you some help. You are not an electronic's technician or BSEE, If you were you would not have posted the symptom listed above, but would have already troubleshooted and possibly even repaired the unit. Johnharold3 you will also need to see some youtube video clips of LCD monitor disassembly,just so you can see what is inside a typical LCD. It may also be of interest to you to find out what are the top two or three reasons why so many LCD monitors (all brands) are failing prematurely. Well, anyway, it seems that the only options you have will be to trade in and get new, OR repair your current unit. Bye for now.I'm louie12fix on fixya or lmistyrel @aol.com
Sep 25, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Mine has the same problem, orange LED with humming sound coming from the speakers etc.
Someone brought one to me to look at..same problem. Checked power supply (easy to check, take off bottom cover and measure voltages on connector. standard 5, 3.3, and 12v outputs going to maine board.) Power supply was fine. took out main board and noticed several 100uf,16v caps that seemed to be bloated. replaced them and the unit turns on. Only thing i'm not sure about is the time it takes to initially turn on. when you first turn on main switch in back, the front led flashes green for about a minute then the LCD comes on and says "loading" which takes about 2-3 minutes, then the unit goes into standby mode (red Led) the unit will turn right on and off again quickly as long as the main switch in the back is not turned off and on again. Is it normal for it to intially take so long to boot? I do not know the normal operation as this is the first i attempted to repair.
Jul 03, 2009 | IceBox IBFS1 LCD Television
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Beyond Icebox computer
Depends on if you are trying to use a wired or wireless connection. Make sure if you have a wireless card that it is a compatible one. There are only a select few that will function properly on the icebox. If you are using a hard wired connection then make sure you have gone into the connection settings on the icebox to configure the internet and what network to use. When you do this you will be able to connect to your network and surf the web.
Feb 01, 2009 | Computers & Internet
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
Electro Med Services...
