Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Seagate drive will not spin up.
Pc power supply was taken out by a power surge, which apparently has taken out the controller on the disk drive. Are these controllers available?
  • RHytonen Jun 17, 2008
    Had exactly the same sequence of events, same reasons.
    I bought an outboard USB controller but the drive wouldn't spin up,
    and a burning resistor/semiconductor smelled.
    Looks like a bypass chip cap where the PS enters.
    Bought a new 'puter (MoBo probably went out as well) but still need the data desperately.
    I'll probably try finding a rebuilt identical drive cheap and replacing the whole board on the drive.
    If nothing else looks burned, I may try just lifting that bypass cap for long enough to dump the data.
    Rod Hytonen
    Guru:
  • 1,894 Answers
Better go for a old hard disk from ebay..
u can get it from there..
but the replacing part can be one by u only if u r expert in chip level sevicing..
Posted on May 30, 2008
Seagate ST91430AG not detected in Windows 7
people solved this same problem for both windows 32 and 64 bit hope i helped somewhat
@ lbsign fucknikco
^twitter (no spaces)
@ switchblades and *******
^instagram (no spaces)
http://www.tomshardware.com/forum/869-63-seagate-freeagent-windows
Nov 02, 2012 | Seagate ST91430AG - 1GB 4.5K IDE 3.5""...
Seagate spins up clicks spins down
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Aug 20, 2012 | Computers & Internet
No power on seagate
probably the hard disk is dead
usually the supply controller on the hard disk ie the main reason.
unfortunate its difficult and not worth to try to fix it when you remember the damage than can be done to the info on the disk
sorry
http://www.rylwy.com/
Jul 28, 2012 | Computers & Internet
Seagate Barracuda 7200 1TB spinning but not mounting
Man it sounds like it just died on you out of the blue... Maybe you had a power surge or something and you didn't know it.
Jun 30, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
Starts to spin then stops
Either the power supply is failing, or the drive has gone defective.
Check with IOmega, it's probably under warranty.
If it isn't, open up the casing and see whose drive (ie, Seagate, Samsung, Maxtor) they used, because the drive itself may be under warranty by the manufacturer.
Before doing that though, connect the drive inside your PC and see if it works.
If it does, just permanently mount it in there because the external boxs' power supply is shot.
If it works in the PC and you really need it to be external, just buy an external hard disk enclosure.
They are about $30 in most places, and that'll FixYa right up!
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My portable hard disk is not detecting by my PC/Laptop. it's working on other PC/Laptop. and i also installed my hard disk drivers.it also giving beep sounds.
The power supplied by the pc laptop on the USB is insufficient to run the hard drive.
If you have an external power supply option on the hard drive, please use that.
Sep 06, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hdd power problem
Hi!
Check your HDD with HDD monitor utility to see if it's ok. You can try this one:
http://www.techsupportalert.com/best-free-disk-health-monitoring-utility.htm
If your HDD has bad SMART or power controller or smth like that - then you definitely need to replace HDD.
Also issue may be caused by your PC power supply or motherboard power controller. If HDD monitor shows that your hard drive is "alive", then try to "hang" your HDD to another power cord from your PC power supply and try to connect to other IDE/SATA port on your motherboard.
Also I'd suggest you to try your HDD on any other PC.
Jul 02, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Hard drive will not spin.
I have the same problem with the same enclosure. I found out it is the power supply problem. It worked the first time out of the box. But when the black 12V/5V power supply box heats up, if I turn it off, and on again, my hard drive won't spin up. It had buzz sounds and tried to spin. I think they use a crappy power supply that can't supply enough current during drive spin up when temperature goes up.
My solution is to unplug the whole unit from the wall when you don't use it. That give the crappy power supply time to cool down, so next time when you turn it on, it'll start from cold. This solutoin worked for my 300G Seagate drive. For my smaller WD drive, it doesn't require cold start. I guess it makes sense, as bigger drives require more current to spin up.
Jan 19, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
When i connect my seagate via usb nothing comes up on my pc, the light comes on on the external h/d but nothing pops up on the pc? help please i need precious photos on it. thanks
have you try connect your pen drive to the same usb port, is it working?
If Pendrive is working but not the Seagate hardisk. Most propably is your USB power is not enough to support the External Seagate hard disk, you need to supply more power to the Seagate hard disk by using USB Y cable(1 end connect to Seagate hardisk where the other end got 2 USB connector to connect to your PC).
Jul 30, 2008 | Computers & Internet
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
257 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
