I wasnt able to connect using my modem, then this appears error 679. What does 679 error means?
    President:
  • 2,340 Answers
Error 678 and Error 679 Connection Errors
Error 678 The remote computer did not respond (No dial tone)
Error 679 The Specified destination is not reachable
Both errors are very closely related as they both suffer from the same causes
Causes
ISP (internet service provider) problem.
You have a phone line problem.
Router / Modem is disabled, this can be due to.
The LAN or Phone cable is disconnected.
Your firewall is blocking the connection.
The Winsock file needs to be repaired.
A phone line does not have a line filter installed.
The modem drivers are corrupt.
Spyware.
Your modem is faulty.
Your username, password is wrong.
Incorrect ISP or Router / Modem Configuration
Hope it helps.
Posted on Oct 10, 2010
Firefox display not appear completely
try to update your firefox or maybe you have a connection problem try to restart your modem first.
May 01, 2011 | Mozilla Firefox
What does comm error 20 01 mean on my brother 2820 mean? how do I fix it?
This means that your Brother machine experienced a communications error when sending or receiving a FAX. This is generally caused by either interference on the line, phone line connection or another device on the line.
Try resending the documents and see if the message no longer appears.
If the message still appears, there may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Nov 03, 2010 | Brother IntelliFax-2820 Laser Fax
What does mean error 797
A certificate could not be found that can be used with this Extensible Authentication Protocol.
http://support.microsoft.com/kb/923944
Apr 12, 2010 | Microsoft Windows? Vista Home Premium...
Unable to install for winxp
that means its not compatible.Check your modem which windows are required to use it.
Feb 18, 2010 | D-Link DSL 200 (DSL-200) Modem
Error 633
right click on my computer and go to properties then hardware in that click on device manger and choose the modem option just expand the list it will show the modem which you installed just right click on it and got to properties and choose the diagnostics option and there is one tab down query modem it will communicate with modem if you find the character or response that means modem is correctly installed or if it is not that means you need to re install modem driver.
Sep 17, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
Error code 109144 when try to connect to internet via wii console
Error Code: 109144 There was a problem registering the console to the WiiConnect24 service. What to do:
  • If you have multiple routers and/or modems, try to connect to no more than one router and one modem try connecting from another location.
  • If you are using only one modem or router, something on your network or from your Internet Service Provider is blocking the connection. You may need to contact your service provider for more information.
  • If you do not have the ability to connect from another location (such as a friend's house), please call 1-800-255-3700 so that we may discuss available options.
Feb 01, 2009 | Nintendo Wii Console
Error message during installation of SBG 900
Please check if your modem and change the config to static IP.
Regards
Sep 03, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
