Question about Acer TravelMate 2300 Notebook
Acer laptop power problem
Acer Travelmate 4062wlmi does not charge, Charger is working fine. Does not switch on from mains. When a charged battery is inserted, laptop works fine.
  • Anonymous Aug 07, 2008
    The laptop will charge when its switched off but the second it is switched on, it stops charging. When it dies from flat battery the charge light comes on
  • 458 Answers
Does not switch on from mains.?????????????
Is the laptop lights not coming on when you plug it in? If not refer to the following.
Are you sure that your power plug has not broken loose. You will have to take the laptop apart to find this out. Sometimes the solder joint will come loose. Do not take this laptop apart unless you know what you are doing. The manual can give you step by step directions sometimes. It is not easy to take it apart without breaking the little things. If you do take it apart, take pictures of every step and take notes and even draw picture so you will know where everything goes. You can touch the plug where it is soldered and re-solder the plug. Please be careful. This takes someone with good solder skills to do.
Posted on May 30, 2008
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
Acer Travelmate 6592G Charging problem
The power adapter id under powered by 1.32A that is why it takes a long time to charge and it is putting a lot of stress on the adapter and could cause it to overheat. The ticking sound could be the thermal cut out cutting the power to the laptop to prevent the power adapter from failing.
Mar 17, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
Acer 2480 2247 won't power up -no lights no nothing, pwr supply is not the problem,lid close switch isn't stuck ,pwr. on switch seems fine and power supply jack on motherboard is not broken
Remove the main battery and the power supply, allow several minutes to get rid of any residual charge, now plug the power supply adapter back in and press power "leave battery out" is there any change? if not! remove power supply, now! press and hold power for 60 seconds to reset the laptop. Next install main battery back in and the power supply adapter, power up! if no change, the motherboard is the problem.
Mar 07, 2011 | Acer TravelMate 2480-2779 Notebook
Acer travelmate 5720 battery stopped taking charge, was told battery would be faulty, installed new battery but problem prevails
either ac adapter is dead or the power socket of the notebook is defective and power is no longer charging the battery. if you have a multimeter, test the ac adpter for power.if thers is power then wiggle jack maybe temp charge. i can fix, 7863893088
Aug 12, 2010 | Acer Aspire One PC Notebook
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
Acer Travelmate 2480-2968
You might have to try an new a/c adaptor.
Mar 09, 2009 | Acer TravelMate 2480-2968 Notebook
No power when at switch on
Sounds like the power socket on the laptop may have broken loose from the board. Very common. If you have a multimeter, try and check the voltage ont the tines where the main battery receives it's charge, with the ac adapter connected to the laptop. That will tell a lot. Good luck
Jul 25, 2007 | Acer TravelMate 290 Notebook
Computers & Internet Logo
359 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
