Question about Wahl 9765-301
U can hear the motor running but the blades not moving or cutting
    Problem Solver:
  • 10 Answers
You need to have your blade sharpened or replaced . It is very inportant to clean and OIL !!
after each use!. oil oil oil
You can go to a dog gromer or a hair salon and ask then who sharpens there shears.
Posted on Nov 27, 2010
B&D Hedge Trimmer (HT33) was working yesterday but not today. Motor sounds fine & the blades move back & forth ... just not cutting any foliage ... any ideas?
Mechanical issue. Make sure that the screw that holds the moving blades up against the non moving blade is adjusted properly. If loose, the blades will not be close together during the cutting stroke and no cutting will ensue.
Jul 05, 2015 | Garden
Wahl clippers
Check to see if the blade is moving when turned on. If the blade isn't moving the clipper blade may need to be thoroughly cleaned. If the blade is clean and well lubricated but still not moving you may have blown the motor.
However, if the blade is moving freely when turned on, and the hair/fur is just not being cut (or is cutting raggedly or pulling at the hair/fur) you will need to get the blade sharpened.
May 02, 2013 | Wahl U-Clip Deluxe Home Grooming Pet...
Motor buzzes, fan does not move, blade does not move, blade is clear of obstruction
Removing blade will not do it - there has to be an obstruction in the drive mechanism that prevents it from turning. Leave off till fixed lest you risk burning out the motor completely. Turn on AFTER you can turn the blade freely.
Sep 03, 2017 | Remington 3-Amp 17" Extended Reach...
My dad's old craftman table saw will not cut straight. I put a new carbide tipped blade in to try to solve the problem with no luck. the wood is cut narrower in the center and it won't stay tight against...
Your problem could be one or more of... 1- Check to see that the motor mounts are secure and the motor is not moving around. 2- Check the shaft that holds the blade for the same problem if the blade is not directly mounted to the motor. If there is any "give" in the above two ways the blade could be held in place, corrections must be made to secure the blade so that it does not "wander" during the cutting procedure. 3- Be sure the fence you are using to guide your wood is set as parallel as possible to the blade so it does not cause the wood to follow another line once the wood being cut goes beyond the cutting blade. There is most likely an alignment procedure you can run through.
Sep 14, 2010 | Garden
Our hampton bay fan has stoped spinning but lights still work, why would the fan itself all of the suddent stop working? thanks
One of the biggest problems I have encountered with ceiling fans has been the wearing out of the manifold, the rubber device that holds the fan blades to the motor. I have never seen them fail where all blades fall off at the same time, but I guess it is not impossible. If this has failed the blades would still be hooked to the outer ring, but not move even when the motor runs. If you can hear the motor running and the blades are not moving it may be the manifold. If the motor is not running it seems obvious that it is a motor problem or a motor controller/remote controller problem. Not easy to repair.
Aug 29, 2010 | Dryers
Remote control works the light on my Hunter ceiling fan but blades do not move
Can you hear the motor run even though the blades are not turning? If so, the manifold/flywheel may be bad and perhaps have broken away from the motor shaft.
Aug 28, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
My wiper blades are not moving
If indeed you can hear the wiper motor running but the wipers are not moving, there is a nut under the pivot point cap that has to be tightened. If you don't hear the motor running than you'll have to check the power to the wiper motor and the fuses. Good luck. Dana
Jan 06, 2010 | 2004 Chevrolet Impala
Blade does not move when turned on
Try spraying the blade assembly with a good rust remover like PB Blaster or even WD 40. Might be something is rusted and won't let blades move. When you are done trimming reapply some oil to displace any water that comes out of whatever you are trimming.
Good luck
roundo4
Aug 09, 2009 | Black & Decker Hedge Trimmer
The paper will not go through my shredder
Can you actually see the cutter blades rotating? I have seen gears broken and you can hear the motor running but no blade movement. Remove the screws lift the top off carefully because their is a short ribbon cable connected to the main board and can easily be damaged. Of course unplug from power outlet first.
Gears and motor can be puurchased.
May 12, 2009 | Fellowes Powershred 420-2HS High Security...
Wahl 9765-301 Logo
133 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
