Question about Craftsman Air Tools & Compressors
I have a Devilbiss Air Compressor that the Pump has started leaking oil badly. There is a lot of end play in the crankshaft. This compressor is 22 years old. Should I buy a new pump or a new compressor? The scfm on this compressor is great where the new compressors are much less scfm and hp. Mine is a 5hp, 20 gallon tank.
  • 4780hb Oct 09, 2010
    The Model # is 919.176850
    Thanks for your reply. What about the excessive play in the crankshaft? I can pull on the pulley back and forth and the crankshaft moves quite a bit. If this was a car, it would not be rebuildable due to the end play. I do not know what the specs are for the end play on this pump or if it is supposed to move that much.
I would opt to reseal this compressor.
Posted on Oct 09, 2010
  • 2 more comments
  • Stew Brunner Oct 09, 2010
    End play is not as critical as up and down. If the up and down is minimal,try a new seal.
    The worst scenario is a few bucks for a seal and a little time. Good luck
    I am just concerned that after 22 years of use, the crank seal may not be the only thing needing replaced. I do not want to waste time and money if the end result is not going to be a properly functioning compressor. If I need to buy a new one after messing around with this one, you know what I mean?
    I have had my compressor for over 25 years. I have maintained it properly for all those years.
    I have a 5 hp 120 lb 50 gallon tank. If you are finacially able buy a new one and leave me alone. stew
  • 4780hb Oct 10, 2010
    May God richly bless you!!!
How do I fix my Devilbiss 5-20 air compressor?
Either the pressure switch is set way out of wack or it is bad
Oct 02, 2016 | DeVilbiss Air Tools & Compressors
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
How do I get pulley/pump balancer off motor going to a DeVilbiss pro 4000 air compressor. Pump went bad and putting another type pf pump on.
Use a puller. Find one or rent one for no cost at auto zone or Oreillys. Requires a deposit with money back after return.
Apr 23, 2015 | DeVilbiss Air Tools & Compressors
Devilbiss air compressor Running hot and low pressure
Chris:
Sounds to me like you have an air leak somewhere. When the compressor motor runs for too long a time, it's 'gonna get hot! Disconnect the fittings one at a time and use Teflon tape at each air connection. Check for leaks using a soap and water solution at each fitting.
Jun 02, 2013 | DeVilbiss Air Tools & Compressors
1988 20 gallon 5hp sears air compressor leaking quite a bit of oil. Can it and is it worth repairing?
I would think that is is actually coming from the crankshaft seal and running down. Does it leak when you are not using it, or just when it is being used? If it leaks even when it is not being used then it could be the drain plug. If it only leaks when being used then I would look at the crankshaft seal. And yes it would be very feasable to repair it, because like all things they don't make them like they used to.
Apr 23, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Crankshaft pulley r/r
Place the crankshaft pulley bolt removal tool over the end of the crankshaft bolt. Tool will hold the pulley in place while you apply torque to the bolt with an impact wrench. Start the air compressor by plugging it in and turn it on. Set the pressure of the compressor on the highest setting. Attach air hose on the air compressor to the air inlet and the locking mechanism using the quick-connect lock on the end of the air compressor hose. Set the impact wrench to turn counterclockwise. Spray the crankshaft bolt with penetrating oil. Make sure you soak the bolt head in oil so that it is easier for the wrench to remove. Secure the socket end of the wrench to the pulley bolt and pull the trigger on the impact wrench. You might need to reapply penetrating oil several times during this process to loosen the bolt up. Eventually, the bolt will come off 215 lbs torque, and simply stated righty tighty, lefty loosy. Hope this will assist you.
Dec 19, 2011 | 1991 Honda Accord
Having problems with my champion air compressor
Crankcase vent may be stopped up. Could have too much oil in the compressor.
May 28, 2010 | Champion International Champion 532 2...
Husky Air Compressor has rattlling noise!
buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
Nov 16, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
The unit only blows warm air. it just stopped kicking on the condenser/compressor to make that radiator cold and blow cold air. any help?
The compressor is not starting either because:
1. The compressor has gone bad
2. The system is low or out of refridgerant. There may be a slow leak, when there is no refridgerant in the system the compressor will not start.
Fix:
Re-charge the system with appropriate refridgerant, if the system has a charge already or holds a charge when you charge it then the compressor should start.
If not the compressor could be bad, sometimes you can get a hard start kit instead of replacing compressor. If the system does not hold a charge then you have to find and repair the leak before anything else...
Good luck. Please give good rating, it meens a lot to me....Feel free to contact me again...
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Air Tools & Compressors Logo
200 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
