Question about Sharp AL-1641CS Laser Digital Copier
We bought a new cartridge for our AL-1631 copier. Up until the time we installed the new cartridge, we never had a problem with this copier. Now the copier indicator light is telling us that it needs a new cartridge. I have shaken and thumped the new cartridge a multitude of times hoping that the toner was caked. For a few times, that seemed to work, but each time the copier is shut down and we try to make copies, we get the same indicator light that tells us that the cartridge needs to be replaced. We have probably only made a couple of dozen copies on the new cartridge, so we know it's not empty. Any ideas? There seems to be a 'clicking' sound that should stop when the copier is warmed up, but it just keeps clicking until the unit shows the indicator light warning of an empty cartridge.
  • 1,110 Answers
Sounds just like an empty cartridge. There is a bar with a long spring on it inside the toner cartridge. As the machine tries to add toner the bar "scrapes" the toner while stirring it in order to ensure all the toner is used. When the chamber is empty or near empty you can hear the spring making more or less a thump thump kind of noise about every 5 seconds or so. If this sounds like the noise you are hearing then it sounds like the toner chamber is empty. Did you buy this cartridge locally? If so you may be able to return it. Was it refilled? Remanufactured? or was it in a OEM Sharp Box with AL100TD or similar on the box? It sounds like either you got a bad/empty cartridge or the only onther possibility is, and I actually had a customer do this once, was accidentally put the old one back it the machine. Pulled the old one out. Unboxed the new one and somehow slid the old one back in. Worst thing was they threw the "new" cartridge away and by the time the light came on again it was long gone!
Good Luck and Thank You for using Fixya.
Posted on Oct 09, 2010
Testimonial: "Glad to recommend the thoughtful input!! Will use this fixya website again in the future."
  • shirleyfanni Oct 10, 2010
    Thank you for your input. We bought the new cartridge at Staples. I was wondering if maybe the new cartridge was not exactly compatible with the Sharp copier. I should have just kept the original empty Sharp cartridge and had it refilled instead of recycling it. I suppose by using an 'offbrand' cartridge, I've now negated any warranty. Not sure what to do - but THANKS for the answer posted. (I was hoping for a simple answer like a reset button!! :o) )
  • Edwin Martens
    Edwin Martens Oct 10, 2010
    If the box was a "staples" branded box then it is a refill. I would take it back and exchange it, either with another staples unit or a Sharp OEM one if they carry them. The warranty on the copier long since expired so no worries there. Be sure to update my helpfulness rating if I have helped you. Also we are having a contest this month based on testimonials so if you would care to leave one that would be great.
    Thanks,
    WheatlandServices
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Feb 08, 2010 | Sharp AL 1631 Copier
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
Nov 12, 2009 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
Sharp al 1631 error code "CH"
it is signal door open or cartridge unite not atast
Jul 24, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Drum Icon only blinking
Hello sir; After install drum unit you need to reset, the procedure as follow;
1, press "#", "*", "clear", "*",keys.
2, enter 24 press start enter 07 press start.
3, turn power off and back on.
Jan 31, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Sharp AL-1641CS Laser Digital Copier Logo
157 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
