I have several (20 ) Dell GX280 standard desktop machines which upon switch on do not boot. The problem is the system board. The processor fan, after a short while, races. Is anyone aware of a mod or fix for this common fault. I am a qualified techie but this is baffling me.
Hi bro just check the usb pin first then check the battery then after check for mother board non of this solution will work for u.
Posted on Oct 17, 2008
    Sergeant:
  • 458 Answers
Have you tried to flash the BIOS? I am sure that you though of this, but sometimes we techie's have brain block.
Are they any jumpers on them?
Have you swapped the memory around?
Just trying to jar your memory on things to check. I am sure that with (20) of them that you are pretty frustrating. What does Dell say? Curious to find out what you figure out. What motherboards are in these? Are they all the same motherboards. Stupid question, but just wandering. I would be really mad if it were me. I am sure that you have thought of everything. I f you let me know what you have tried, I might be able to think of something that you have not tried. I just looked these up and they got great reviews. Strange that none of them work. Have you tried the processors and memory in other machines? Keep me posted on what you figure out.
Posted on May 30, 2008
Gx280 powers up but no boot cpu fan runs out of control
I had the same thing happen on my Dell. I found the processor was bad,
Jan 18, 2013 | Dell OptiPlex GX280 PC Desktop
Help me i have gx280 tower type 3.0 ghz 20 machines i bought these machines from used markete few machines are trouble in cpu fan abnormal noising i removed al types of hardware components but...
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Aug 06, 2011 | Dell OptiPlex GX280 PC Desktop
A message says "previous fan
my dell gx 280 fan failure how i solve it'
Nov 23, 2010 | Dell OptiPlex GX280 PC Desktop
I have dell optiplex GX280 System in unbranded casing, Kindly suggestion about Processor Fan Voice, he is so shouting
The fan(which runs on a bearing) has aged, it must be replaced. Luckily this is an easy and cheap fix. Pick one
http://bit.ly/9qzXBz
May 30, 2010 | Dell Optiplex GX280 (99301) Motherboard
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
I have Dell GX280 system. My Fan produces more sounds and runs fast. System Hangs while processing and performs slow, causes processor nore hot. I pasted the Heat Sink Paste on processor that resuls in low...
More than likely your fan needs to be replaced. These small form factor Dells are know for problems like this. Warning! Do NOT attempt to blow out the CPU fan with canned air, as this will likely lodge dust particles in the axis of the fan causing it to drag and become louder!
Sep 09, 2009 | Dell OptiPlex GX280 PC Desktop
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
How do i replacea fan on a dell gx280
First select the chassis type of GX280 you have from the link below
http://support.dell.com/support/edocs/systems/opgx280/en/ug/index.htm
The page would redirect you to the user manual for the system
Look under Add Remove components > Processor or motherboard.
The Fan removal instructions are given step by step with pictures
Thanks
Proton
Do rate the solution
Apr 30, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Nov 16, 2008 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
