Question about Microwave Ovens
User guide for Panasonic Inverter dimension 4 Micro wave CT7765BPQ
MicrowaveSvc
  • 9098 Answers
SOURCE: PANASONIC NNC753BBPQ DIMENSION 4 800W MICROWAVE
You will find that here.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Micro Wave shuts down
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
SOURCE: Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Posted on Apr 16, 2009
sandrineFY
  • 268 Answers
SOURCE: I have lost my user manuel for my Panasonic
Hi, You do not indicate which Panasonic microwave you have. Check this site, it has a lot of manuals you can download...maybe yours is in the list: http://www.retrevo.com/samples/Panasonic-Microwave-manuals.html Hope that helps.
Posted on Sep 14, 2010
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
Door closes but will not turn on . Have to slam it Model # NN-SD698S Inverter S/N 6810190386
There are micro-switches in the control panel that are out of adjustment or sticking.
The switches have to make contact with the door latches when the door closes.
Adjust the position of your switches.
Jun 11, 2011 | Panasonic Microwave Ovens
Panasonic Dimension 4 microwave switches off
Try resetting it--aka, unplug for about an hour, then plug back in and try again. If that doesn't work, make sure you try a different outlet, and if all else fails, contact Panasonic. They should be able to help you out with a repair/replacement (and if you're still under warranty, usually it'll be free!).
Their phone number (acccording to their website, www.panasonic.com ) is 1-800-211-PANA (7262)
Good luck! :)
Aug 27, 2009 | Microwave Ovens
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic inverter dimension 4 microwave oven runs for 27 secs in micro mode then cuts out no heat either convection oven grill work fine ????
Sep 03, 2008 | Panasonic Microwave Ovens
Micro wave operates for a few seconds then shuts down, light goes out, but fan continues to work
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
The oven will also strop after 22 seconds if there are certain problems with the inverter or magnetron.
In most cases, this is a problem with the inverter or a bad magnetron.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
114 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
