Question about Coleman Heating & Cooling
Roof top Ac the commpressor does not seem to be kicking on fan works any thoughts.
    New Friend:
  • 107 Answers
Several things can cause this. The most common are a bad compressor, burned off wires, and bad capacitors. Turn off the power and check your wires in the control box and at the compressor. Look at your capacitors for signs of bulging. Replacements can be purchased at local ac or electrical supply houses.
Posted on Oct 10, 2010
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
How do I check my ac compressor? it is not
Hi: Check and Make sure that the Fuse or Relay Swicth is Good if They Are Then Go to Plan (B) Find you a Partner to turn On and OFF A/C while you look to See if your Air Compressor Clutch is Engaging and Turning your Commpressor .You'll hear Click if its Engaging ,And If it working right you'll See that ALL The Pulleys are Moving/Rotating. If the Commpressor Clutch is Turning your Commpressor.If Clutch is not Engaging the Commpressor Go and Get a New Clutch and Install it. Hope this gets you the Help you Need, Please Reply By Voting on How My Solution Has Helped You. Thanks FROM: The WYOCWBOY
May 29, 2010 | 1999 Chevrolet Lumina
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Replacing the ''wood'' in the top(ceiling) of a pop up camper. Cant seem to find a correct listing for this in the menu.-----------but this is for a Tracker pop-up camper. It started leaking around the...
i would suggest getting a price on the entire roof assembly from a dealer depending on age these roofs can be lminated togehter ang removing the skin car cause strustural damage to the camper roof it is common practice to stop the leak remove most of the wet wood and overlay what is left standing sounds bad but only way to fix cosmetcally if you need to soarce parts do a search for all right manufacuring they supply celing and metal for most camper manufacures
Jun 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Outside ac compressor not kicking on when ac turned on
Most of the time the capasitors are bad but it could be that the commpressor is bad or if it is a heatpump the low pressure switch could have it locked out or the contactor could be bad also
May 02, 2009 | Heating & Cooling
Ac not working
You are right the fan is going out. When you change it out be sure to replace the capacitor. This is something you can do it is not easy but no way hard either. If you have any questions when the time comes get back with me and be glad to advise. ken
Apr 22, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
