Question about Garmin nuvi 750 GPS Receiver
I am thinking of buying a Garmin Nuvi 765T on ebay, but the description says it is locked with the PIN. Is there a way to bypass the PIN aside from the safe location? Obviously Garmin has a procedure since they will override it with a registration and receipt from original seller
I want unlock my gps 750 garmin
Posted on Oct 21, 2010
I just brought a garmin 250 from a bootsale but it has a pin lock anyway i can get a code?
Unless the vendor supplied it, you cannot operate a locked Garmin and you cannot bypass the code.
The following is cut and pasted from my existing FixYa Tip and deals with your precise problem:-
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of first purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
You may read advice elsewhere advising you to use a secret menu to erase all user data. This is done by starting with the nuvi switched off and then pressing and holding the bottom right corner of the screen and then, whilst still pressing the bottom corner, turning the unit on. Please note that although this erases all previous user data, it does not bypass Garmin Lock. There is NO bypass for Garmin Lock except by taking the unit to the owner's security location; it would be a useless theft deterrent otherwise.
Jul 19, 2011 | Garmin nuvi 250W GPS Receiver
Hi. My Garmin sat nav will only charge for approx one hour, then stops charging altogether when using the car charger, if i use the usb on my pc it will charge fully, also it will charge fully when...
From your description I suggest purchasing a new car charger probably a weak component in the charger itself. You can get one at Garmins website at www.garmin.com but I think you will find one much cheaper on Ebay.
I hope this helps you out and if it does please leave me some positive feedback.
Apr 04, 2011 | Garmin nuvi 765T GPS Receiver
Cannot register my nuvi 765t
Contact Gamin customer service, someone in Garmin may have type in your serial number for someone elses garmin nuvi 765t, it happens once in a while, nothing to worry about, just call Garmin and get it resolved.
Apr 03, 2010 | GPS
I tried to update my garmin. The screen doesnt move (or continue to download) I allowed for block ups.
You need to download and install the Garmin WebUpdater and Garmin Communicator Plugin both available from Garmin's website onto your computer. This allows updates to be installed directly to the 765T and provides the necessay USB drivers as well. The 765T must be connected to your computer when performing all updates or upgrades.
You may need to create a MyGarmin account and register your Nuvi 765T.
Resetting the 765T: with the unit off, press your thumb or finger in the lower right corner of the screen while turning the 765T on. This will clear all user data, base map software will remain intact. Connect 765T to computer and proceed with the Garmin WebUpdater.
Dec 22, 2009 | Garmin nuvi 765T GPS Receiver
My nuvi 765 will not turn on. Any solutions? How do you reset it? Vista will not even recognize the Garmin in the USB port. I'll assume that it's because it can't communicate to the OS. :) It just shows...
Resetting the Garmin Nuvi 765T: Press and hold your thumb or finger in the lower right hand corner of the screen while powering the unit on. This will erase all USER data, base and detailed maps will remain intact.
Connect your Garmin Nuvi 765T to your computer via USB.
Download Garmin's Communicator plugin and WebUpdater, both applications can be downloaded from their site. By doing so, this will load the necessary USB drivers to your computer, allowing the Garmin Nuvi to communicate and update firmware and software via the plugin and WebUpdater.
On Vista, the Nuvi 765T appears as Garmin Nuvi without the "T" as well, (a blue triangular icon also appears) it does not affect the ability to transfer files or explore the device in any way. If you load an SD card into the Nuvi 765T, it will appear as a removeable disk and assign it a drive letter, in my case H:
Dec 11, 2009 | Garmin nuvi 765T GPS Receiver
NO POWER TO MY GARMIN 765T
Visit garmin web site for software upgrade for free also read : http://www.amazon.com/Nuvi-765T-died-tonight/forum/FxFTK8E026BG45/Tx3LG8KEDC3FWNU/1/ref=cm_cd_ef_rt_tft_tp?%5Fencoding=UTF8&asin=B001ELJER4
Jul 28, 2009 | Garmin nuvi 765T GPS Receiver
Garmin nuvi 750 GPS Receiver Logo
190 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
