Question about Cuisinart SM-55 Stand Mixer
My Cuisinart stand mixer won't work. It is getting electricity -- the timer light is on -- but when I press the on/off button, there is a click and no movement. This happens with the blender attachment, as well as the mixer. I think it is the motor. It is in a dedicated cabinet, and has been plugged in constantly. I have unplugged it to reset it, to no avail. Any ideas?
  • 3 more comments
  • trenton_deac
    trenton_deac Mar 28, 2012
    Traced the circuit on the board for days to find the problem. If you have an original unit you have a optocoupler on the board made by Sharp PC817b. It has died. The refurbished units now use a Sharp PC817c which is higher rated. You can order the higher rated unit online and replace it with some decent soldering skills. Verify by testing the diode across pins 1 and 2. Make note of the orientation of the chip on the board and replace. Be careful to not heat the chip up to much as this will burn the diode out again. This replacement will likely void your warranty. I wasn't going to pay for shipping on this thing. So I voided away! :)
  • Ben Franske
    Ben Franske Nov 09, 2013
    I had the same problem. I ordered some Sharp PC817c optos from ebay and replaced it which fixed the problem. A couple notes... The control board is inside the grey plastic enclosure in the vertical part of the mixer, you'll also need to take a heatsink off the control board in order to get to the opto, otherwise a very straightforward repair. Mine now works great again.
  • Ben Franske
    Here is what the control board looks like removed from the mixer and the heatsink removed.
  • Gail
    Gail Nov 28, 2013
    I am trying to replace the relay on my SM70 mixer. Someone removed the original component so I don't have the particulars to order another. I believe it is by Omron. I am hoping that one of you folks might have an idea of what I am looking for. Thanks.
  • John Schonewille Dec 04, 2013
    Seach for "Mikofox " here, maybe a pm would get you on track, it is quite easy if you have (de)/soldering expeirience.
  • 10,594 Answers
It sounds Motor Control Board got problem as you hear relay click but motor does not get power to rotate from motor control board.
It is electronic hardware failure issue, its not user level repair and professional can do it.
Click Cuisinart Contact link to find out nearest repair center in your area.
Hope these info will help you.
Thanks.
Posted on Oct 09, 2010
Attachments not turning. Small screw located next to accessory power port unscrewing when mixing.
Paula, Put a drop of loctite on screw and insert securely, let sit to dry 24 hours to cure.
press the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | Cuisinart Cusinart 5.5-Quart Stand Mixer
How can i fix this problem
PDF]SM-70 INSTRUCTION BOOKLET 7.0 Quart Stand ... - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/sm-70.pdf
Cuisinart7. Do not exceed the maximum capacities listed in this use and care instruction book. 8. ... Troubleshooting . ... extra-large Cuisinart™ 7 Quart Stand Mixer.
Jul 30, 2015 | Cuisinart 7 Quart Stand Mixer
How to add oil to cuisinart SM-55 stand mixer
The owners manual is available on the website. It doesn't mention anything about adding oil. What makes you think it needs oil. Mixer gears are usually lubricated with white grease and are maintenance free.
Nov 23, 2013 | Food Mixers
Cuisinart SM55 circuit board replacement or wiring chart.
I have a Cuisinart 5.5 quart stand mixer. but its count down model does't work. it move as fold model when I push on button. I guess the circuit board was broken. Is my guess right? Where can I buy the Cuisinart SM55 circuit board and how to replace it?
Jul 23, 2012 | Food Mixers
My cuisinart 5.5 stand mixer when you press the on button it starts for a second then it stops.
Make sure the plug is securely plugged into the wall.
Next, remove and reattach any mixing arms etc that may be attached to the mixer. Having one not attached properly can result in a start, start.
If problem persistes make sure the speed is reset.
If problem continues, here is an excerpt from the user manual found here.
http://www.cuisinart.com/share/pdf/manuals/sm-55.pdf
Problem: Your stand mixer has an
overload protection device and if
overloaded, it will shut down to protect
the motor.
Solution: In the unlikely even that this
happens:
• Turn off and unplug the unit.
• Reduce the load by removing some of
the ingredients, and allow the mixer to
stand for a few minutes.
Plug in and reset the speed. If the
stand mixer does not start when you
press the on button, allow the unit to
stand for additional time.
If you are still having trouble, the product comes with a 3 year limited warranty, so if you're bought it within the last 3 years it may be covered.
Good Luck!
Mar 01, 2011 | Cuisinart SM-55 Stand Mixer
Cuisinart SM-55 Stand Mixer Logo
3,356 people viewed this question
Top Cuisinart Food Mixers Experts
Ross Keen
john h
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
