Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
How to do dmz on motorolla sb5100 ? - Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
IS THERE A WINDOWS7 DRIVER FOR the sb5100
Hi
Try to install the same driver for Windows xp
in windows 7 in Compatibility Mode
For running in Compatibility Mode in windows 7
Right Click the app and select the properties
select the Compatibility Tab
select the os =windows xp sp3
and dont forget ti tick "Run ad Administrator"
Download Here th driver(xp)
Feb 10, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I need the driver for the motorola modem sb5100 usb
http://www.opendrivers.com/driver/213444/motorola-surfboard-cable-modem-sb5100-usb-driver-2.4.1-free-download.html
Jan 20, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Does the Motorola SB5100 SURFboard Cable Modem Work with XBOX Live?
You can find information on getting hooked up with your modem here
Good Luck!
Jesse
Jan 05, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I am about to change from dial up to broadband using Motorola's SB5100 series cable modem which was given to me. Should I remove the dial up bits from my computer before installing the SB5100, or just...
It is best to remove the dial up portions because it will help eliminate confusion within your system as to which connection to use. You will be much happier once you get hooked up with broadband....good luck.
Oct 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need new ip and mac adress for sb5100 motorola for southwest
To get new IP unplugg power for 1 minutes the plug the power back in. MAC address is a unique identifier specific to that modem. To get a new MAC address you will have to buy a new modem.
Sep 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I want my Iphone to get my e-mail, I have a router sb5100 can it be changed to a wireless?
if i remember correctly the sb51xx is wired series so you would need a wireless router linksys is reccomended
Aug 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I need to setup my motorola SB5100 cable modem to accept remote desktop connections. can anyone help?
by defualt it should be able already- you may want to check your computer and make sure there are no firewalls blocking you.
May 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need to get wireless on my laptop,
No, the SB5100 is just a cable modem, not a wireless router. You will need to keep your sb5100 but you will need to purchase a wireless router if you want wireless on your laptop. If you can also plug your laptop into the sb5100 via an ethernet cable for your internet connection. Linksys and Belkin and others make wireless routers that you can use for your wireless connections.
May 01, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
CONFIGURING MODEM WITH VISTA
That should be plug and play.
I would check with Motorla and see if there have been issues with it.
Jun 11, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Xbox 360 live troubleshooting
Assign a static IP address to the 360, then go into your router's setting and set a DMZ for that static IP.
Oct 25, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
140 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
