My asus 100p netbook is not charging. its only 2 months old and now when i plugged the adapter its is lighting but the battery indicator is not lighting. i am running low in battery now.
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the netbook & charge the battery. A very good way to do this is to compare your netbook voltage & ampere requirements (written on a sticker on the bottom of the netbook ) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the netbook's voltage rating. Amperage of the power adapter should be at least equal to or greater than the netbook's rating. It should never be less than the netbook's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the netbook, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the netbook & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another netbook, or try a good or new battery in your netbook.
If this did not work, there might be a possibility that the charging circuitry on the netbook's motherboard is defective & needs servicing. In order to do this, the netbook needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the netbook's motherboard altogether.
Posted on Oct 09, 2010
I cannot turn Asus netbook on - not charging, no indicator lights on
Could be a duff battery, does happen. are you. do you have a ampre meter to check charge
Jan 28, 2013 | Computers & Internet
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
ASUS netbook 1005 HA charger won't stay in to keep charging battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 08, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My asus netbook's battery is not charging, even if i left it charging for hours it still has 0% available on the battery. what will i do? tnx!
hmmm that is a little weird
does it work without the battery by chance? sounds a LOT like the adapter is not working therefore battery can't ever get a charge \
let me know what you discover
May 22, 2012 | ASUS Eee PC T101MT Netbook
Battery adapter not charging
The DC jack in the laptop causes all kinds of symptoms from intemittent operation, no power, and will not charge battery, the laptop will need to be dismantled down to the motherboard level to address the situation.
May 05, 2012 | ASUS Eee PC 1000HE Netbook
I hav my ASUS Eee PC 1101HAB netbook, i was charging it while im using,after an hour or two, i noticed that it stops charging. i checked my charger and saw that the LED is off. i tried to unplugged it, and...
Hello.
Hello.
The most common reasons are the battery, power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
In any case, since your netbook is still under warranty, I strongly advise you to return it where you purchased, for a repair or replacement. A two-month old network should not have power problems.
Hope this helps.
Dec 26, 2010 | Computers & Internet
I bot a hp mini laptop recently.. ws working well..bt sddnly it ws nt chrgng ystrday and showed cross sign over battery in control panel.. why is it nt chrgn and wht to do?
If the laptop is still working when it is plugged in , then the ac adapter is good and the battery is just bad. If the laptop will not work when it is plugged in then more than likely the ac adapter is bad.
Oct 27, 2010 | HP Mini 1000 Netbook
The battery will not charge if it runs down
HI there,
When a laptop/netbook will run on the A/C Adapter but the battery won't charge, there are only 3 things that can be wrong.
1. The battery is dead (replace the battery)
2. The A/C adapter's charging system is not functioning but the power function is. (replace the A/C adapter)
3. The DC power jack which is where the adapter plugs into the laptop is partially failing, providing power but no charging. (replace the DC jack)
Try to find a friend with an adapter/charger that fits your netbook and see what happens with that first. If that doesn't work, try to find someone whose Netbook takes the same battery and test if yours will charge in their laptop. After that, if your battery's not dead and you have a working charger, it's the DC jack and that costs about 80 to 100 to be replaced. They have to take apart the netbook, remove the jack and solder on a new one.
Good Luck
Marcus
Sep 14, 2010 | ASUS Eee PC 1000HE Netbook
Asus netbook ac power cord adapter stopped working...no blue light on...not charging computer...what to do and need new one?
You need a replacement AC adapter, it's very cheap online.
1)Output Voltage is within +/- 5% of your old charger's output.
2) Output Current is the same or higher than that of your old charger.
3) Connector tip must fit securely into your laptop.
Jul 15, 2010 | ASUS AC Adapter- Universal Notebook AC...
Computers & Internet Logo
268 people viewed this question
David Payne
David Payne
