Question about E-Machines Computers & Internet
I'm trying to restore my system to factory settings after repeated crashes (BSOD's). It gets to a certain point in the resore process, where it's copying files, then it just stops. No blue screen, no error message, it just stops. I chatted with eMAchines tech support & they say it's a hardware problem--nothing more specific than that. Any insight is appreciated.
  • thewoolcotts Oct 09, 2010
    Thanks for your prompt response.
    I looked at the post you linked. I've tried letting the machine "cool off" after a crash, but it's clean & well-ventilated so I don't think that's the issue. I looked at the capacitors on the motherboard (I'd gotten that suggestion before) and they appear to be normal. There isn't anything visibly wrong or unusual on the motherboard as far as i can tell. I've had it in to Best Buy (where I bought it) three different times & they couldn't figure out anything wrong with it, What do you recommend from here?
    I've been trying to restore from the CD's. That's where I'm running into the problem--it begins the process and just stops. I've tried ejecting the disk
    President:
  • 2,653 Answers
Since it's happening in the same spot it's probably due to a bad sector on your hard drive, swap the old hard drive out with a new one (they're super cheap nowadays) install a fresh copy of XP, Vista, Win 7 or Linux and you should be good to go.
If you're savy you can find a program called Spinrite, create an ISO, burn it, boot from it and then scan the drive (advance user advice)
Hope this info helps :)
Posted on Oct 10, 2010
  • 567 Answers
I suggest that you refer to this page for some help on this issue.
As per your description of the issue, it seems to me that you perhaps have blown capacitors on the motherboard.
Another cause of your issue could be a fault in the RAM modules.
I suggest that you visually inspect the Capacitors on the motherboard.
The blown ones will have a curved, arched top and perhaps a black, powdery, burnt look.
If that is the case, get the capacitors replaced first.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 09, 2010
  • Anuj Joshi
    Anuj Joshi Oct 09, 2010
    My suggestion:
    Do not run the System Restore then, try to use the OS CD and format before you reinstall.
Gateway desktop critical error code
Which operating system ???
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
ASUS Eee PC 1005HA-PU1X-BK Netbook how do fix black screen issue?It has an upper left corner blinking dash_
Hello.
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Jun 25, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have a packard bell imedia mc 1538 and need to resore to factory settings, have tried using F10 key with no result just goes to start up. The master cd just does a system restore and not the factory...
If the file that holds the factory settings is gone then there is no way to restore the factory settings back. You can however reinstall windows if you got a hold of a windows disc in the version you want. You can use the windows key on the computer somewhere to activate the windows. I would suggest doing a system restore the the last restore point and removing any unwanted things from there.
May 11, 2011 | Computers & Internet
Wont load windows...just a blue screen with the mouse icon. Alt-f10 doesnt work at the acer screen
Windows is probably getting stuck on start-up and this is likely due to a driver problem. The presence of a blue screen with the mouse pointer icon on it has a description called BSOD (Blue Screen Of Death). BSOD was common in earlier Windows versions as they were not robust enough to withstand misbehaving applications. Current Windows better isolate applications so that BSOD does not occur but it can still happen during the start up process. My suggestion is that you should try running Safe Mode then do a System Restore to an earlier date when the system used to start properly. Strongly suggest that you have the system plugged into its AC adapter before doing this. The following is based on Windows XP (you didn't indicate what O.S. you had).
1. do a power-on and press F8 repeatedly to get the Windows Advanced Options Menu
2. use the up-down arrow keys to highlight Safe Mode and press the Enter key
3. on the Windows log-in screen, click your user name icon to log-on
4. on the Desktop window, click the No button to indicate a choice to use System Restore
5. on the Taskbar, click on the iconized System Restore to open the System Restore window
6. click the Next button to get the Select a Restore Point window with the monthly calendar
7. on the calendar, click a bold date then click the Next button
8. on the Confirm Restore Point Selection window, read and if it is OK click the Next button
9. during System Restore, the system will be shut down and restarted. Let this proceed normally.
Apr 30, 2011 | Acer Aspire One PC Notebook
They stop working. After successfully using them they will simply stop. I get around the problem by taking a system image backup and then restoring to the factory settings. The Fn keys work at that point....
Are you sure that you do not have a function lock enabled? That your keyboard is not set to use the keys as media instead of their original function, or vice versa? Hit the Fn key on your keyboard and see what happens.
Mar 09, 2011 | Computers & Internet
I need to resore my computer to the factory settings but i don't have the disc
Restore discs for Dell and XP are OS with Dell help gui, Mostly online links to their site...look under support.Dell to find any and all drivers and patches. A Dell XP disc does not require you to enter a COA, so get one!!
Oct 11, 2009 | Dell Inspiron 1501 Notebook
System won't boot up
mostly your system resore had been turned off due to this reason, wont take system restore , turn back on
Mar 20, 2009 | Microsoft Windows Vista Home Premium with...
Error 0200 faeluer fixed disk 0
Sounds like the hard drive has crashed. You can try pressing F8 repeatedly as soon as you start the boot process and see if that gets you to the windows repair option. From there you can try to do a repair or restore to factory settings. Otherwise buy a new hard drive and restore with your recovery cd.
Mar 14, 2009 | Acer Aspire 5050-3242 Notebook
System resore
No you don't want to create a restore point, you want to restore the system to an earlier time or recommended restore point
Dec 13, 2008 | Dell Dimension E510 PC Desktop
Factory resore
Mark if you have the Acers restore or rescue disks, you should be able to use these to get your system back up and running.
I,d suggest your problem/conflict With your Application Crash is an incompatable program with vista.
The Only other suggestion i have, is to boot the computer with Vista in the CD/DVD Drive, and re-install over the top of your existing system.
Alternative is to Install Windows XP, More reliable Tried And Tested. And definately more Compatable with Software.
Mike @ compurepair.
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
