SOURCE: FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
SOURCE: Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
SOURCE: Frigidaire side by side freezer-
this should not be happening as a heater in the freezer should eliminate this problem.first check the hose is completely clear,if it is when your fridge goes into defrost mode you should be able to feel warmth near this drain or hear the ice crackling and defrosting thence draining via the rear tube also try removing the offending ice in the drain with hot water
SOURCE: frozen water tube that goes into the icemaker
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the
water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
SOURCE: frigidaire FRS26ZNH frig
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
