Question about Brother Office Equipment & Supplies
I have a Brother MFC 3420C Printer/Fax Machine. It is showing a display of UNPLUG MACHINE, CALL TECHNICAL SUPPORT, MACHINE ERROR 41 Please help.
    Guru:
  • 1,894 Answers
Do a soft reset
Posted on May 30, 2008
  • 1 more comment
  • dewan nafees ahmed May 30, 2008
    else switch off the printer and leave off that for few hours
    Error 41 -The head drive voltage has not been turned from Low to High within the specified time.
    Check:
    • Carriage ASSY
    • Main PCB
    • Print head unit
    • Power supply PCB
    The maintence codes to program a new print head serial number.
    Change the Printer head, then go into Maintenance mode (hold in Menu key while switching on), press 68, 2580.
    Type the number on the Printer head sticker between the 2 *'s (asterisks) in. (Printer Head Property Number). To type in the letters, hold in the # key while pressing 1 for A, 2 for B etc.
    After that press Set to save it.
    Then press 09 for print Quality Test, and check/sdjust the print quality/alignment - instructions on LCD Screen and Page.
    After that press 99 to exit Maintenance mode.
MFC 3420C. I am getting error 41
While there are many ways to prevent Brother printer error code "41
Jul 11, 2010 | Brother MFC-3420C Printer
Dear Sir I have a technical error 41 and i dont know what to do.
When did the problem start on the printer
Thanks
proton
Aug 06, 2008 | Brother Office Equipment & Supplies
I have a MFC-3420C, it says Machine Error 41....call Brother
the problem is with the printhead. you are looking at a repair cost of at least $110.00 depending on where you take it too.
thanks adi
Dec 31, 2009 | Brother MFC-3420C Printer
Problema con impresora MFC-3420C
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Oct 21, 2009 | Brother MFC 3420C All-In-One InkJet...
Help me solve machine error 41on my brother mfc-3420c.
Hi there
Dec 16, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
in.
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Office Equipment & Supplies
What do i do to fix Machine Error 41?
May 30, 2008 | Office Equipment & Supplies
Machine Error 41 and USB Cable
Hi, According to the User Manual any Machine Error (XX or in your case 41) refers to a mechanical problem. You have to call Brother Customer Service (USA: 1-800-284-4329; Canada: 1-877-BROTHER; Montreal: (514) 685-6464. You can also try checking out the machine, if it is new, check that all the plastic/tape retainers are removed (outside and inside); it is also possible that there is a locking lug/nut or screw somewhere (most likely underneath) that is only needed when in transit or when shipped that must be removed/opened/released when the machine is to be in operation. The USB connection is essential, it is the PC interface (and normally should be included in the box but can be bought from any computer outlet). This is how your PC communicates what it wants to be printed to your 3420C. Hope this works for you. Good luck.
Apr 22, 2007 | Brother MFC 3420C All-In-One InkJet...
Error 41 on Brother MFC-3420C. I have tried unplugging and restarting. There aren't any paper jams or visible problems. There is dial tone to machine but fax will only ring when called, no start tone...
Hi,have the same problem since yesterday. Look on fixyourownprinter.com. """You can fix the ERROR 41. Go to www.bopparts.com and look up part# LK0935001. They sell it for $39.99 and it is very simple to install""".Good luck.
Apr 13, 2007 | Brother MFC 3420C All-In-One InkJet...
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
