Question about Infinuvo QQ1 CleanMate 365 Robotic Vacuum
My Infinuvo Cleanmate QQ2 will not accept a full charge. It runs for 10 - 15 minutes and then says "battery low". I have a new battery and charger. I have charged it directly without the home base and have left it charging for days. Any suggestions? Thanks, Linda
Dyson dc30 charging issue
Defective replacement battery - unable to charge/recharge.
Jul 11, 2017 | Vacuums
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
After a full charge will only run for about a minute then stop. New batteries purchased, same result.
If you replaced batteries that only leaves the charger,
check the charger wire for any cracks or breaks in the wire, See if you have another charger that has the same output, check on the charger for output voltage to make sure it is the same. It could also be a problem with the motor maybe a bearing that makes the motor hard to run. Does it get hot?
Tom
Oct 22, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
Scooba not working after full recharge
NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
Apr 08, 2009 | iRobot 5800 Scooba Vacuum
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
Swivel sweeper battery is not charging
The battery is done for sure. take a look here Finally charging for our multi device world and choose the best one for you (by price and seller). cheers
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Infinuvo QQ1 CleanMate 365 Robotic Vacuum Logo
188 people viewed this question
Top Infinuvo Vacuums Experts
JoeVacs
Are you an Infinuvo Vacuum Expert? Answer questions, earn points and help others
