Question about GE (PSS26MSRSS) Side by Side Refrigerator
Noise - not cooling - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 17,130 Answers
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Posted on Oct 09, 2010
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
Haier A/C CPR10XC7-L
The Haier ESA410J-L is part of the air conditioner test program at Consumer Reports. In our lab tests, air conditioner models like the ESA410J-L are rated on multiple criteria, such as those listed below.
Comfort:This is how well temperature and humidity are controlled at the low-cool setting. The best performers held temperatures to within one-and-a-half degrees of the setpoint.
Indoor noise low:This judgment of indoor noise at the low-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
Indoor noise high:This judgment of indoor noise at the high-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
Jul 22, 2012 | Televison & Video
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
Loud noise in front end at 35-55mph. Sometimes gets softer at around 65mph. Loud humming noise that increases in pitch as the speed increases. Noises persists when engine off and the manual transmission...
Electric cooling fan bearing failed and the cooling fan needs to be replaced. Start with inspecting the cooling fan behind the radiator and determine if that is where the noise is coming from. Replace any worn or damaged parts.
Thank you for using fixya and be safe.
Apr 30, 2010 | 2001 Chevrolet Cavalier
Cooling Fan noise
Another possible source for the noise is the Color Wheel. It is spinning at a high rate and the noise will get louder as it wears out. You should be able to replace the part yourself. Take a look here first: http://www.fixya.com/support/t372149-samsung_hlp4663w_color_wheel_replacement
Aug 04, 2009 | Televison & Video
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
Mazda mx 5 engine noise
the noise is caused by the hot exhaust, all cars do this, the exhaust gets up to 1000 degree's. The noise is the metal contracting as it cools, it is a clicking or popping noise.
Feb 21, 2009 | 1993 Mazda MX-3
Water cooling noise
Could be air in the system which you would need to bleed out. Either that or a faulty pump.
Sep 24, 2008 | Thermaltake Symphony mini Water Cooling...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
89 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
