Question about Craftsman Nailer Kit, Palm Air Driver
Hi, I have a paslode im90, it only fires when held upright, won't fully depress at an angle or when on it's side, any suggestions?
I had the same problem with mine,
the spark unit is held in posistion with either tape or silicon depending on the year, this can come loose in time, when it comes loose it puts stress on the wires that come from the circuit board above.
you can secure the spark unit again that can do it, if not you need to replace the circuit board cost between £25 & £30
Posted on Nov 18, 2010
Paslode 900420 it runs and I get spark but it doesn't fire. the cylinder is clean and its a new fuel cell. Do the spark plugs often go bad?
no they don't, where do you get the spark from?? you can test this tool with the cylinder off by depressing the roller lever and holding the switch in the on position. If there is fire across the gap it should work and then I would look to make sure the safety is fully depressing. If this is the one with o rings you might want to check them for wear. Also look at the expiration date on the fuel cell, it is on the bottom and if expired could cause a problem.
Feb 06, 2012 | RTO PasLode 900420 Impulse Framing Nailer
My paslodes will not fire with a fully charged battery and a new full cell. It only makes a sound like its engaging
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 22, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse finishing gun wont fire. battery fully charged and gas is full.
heatman101
Jan 01, 2011 | Omega Paslode 901000 Impulse Cordless...
My paslode angled finishing gun keeps jamming leaving the firing pin in the out position
heatman101
Dec 24, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Fan goes on,only fires at a certain angle.
heatman101
Sep 20, 2010 | BreatheAudio Paslode 900600 Impulse 16...
Paslode im 250 the fan goes on but it does not fire when depressed. I have tried a new gas cylinder
Make sure the battery is charged - it will not provide good combustion.
Next - make sure the plunger is fully depressed - there is an adjustment on the side.
Finally - check for proper operation of the trigger.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 02, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
Paslode Impulse Framing Nailer won't operate
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Craftsman Nailer Kit, Palm Air Driver Logo
631 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
