Question about CyberPower CPH720P 7-Port USB Hub
I just bought a cyberpower cph720p usb hub, but when I plugged it in to my windows 7 laptop I got an error saying "Windows has stopped this device because it has reported problems. (Code 43)". I have tried several usb ports and it doesn't work on any. Is there a driver I need to find and install or should I just assume this is a bad unit and return it?
2 Suggested Answers
SOURCE: Installing USB Hub
finsphan72's response is correct but you could use information one step earlier.
USB 1.1 is the older version of USB.  USB 2.0 is newer and much faster.  Your computer has hardware in it to talk to USB.  Because it is an older computer, it has USB 1.1 hardware.
The USB hub is just a splitter.  It lets you plug in several USB devices while only using one USB port in your computer.  But it doesn't change the fundamental capabilities of your computer.
The only way to get a computer with USB 1.1 built-in to support USB 2.0 is to add a USB 2.0 card to the computer.  This is an open up the computer and install a piece of hardware operation.  It isn't very hard and it isn't very expensive, but it might not be something you are comfortable doing (and it is possible to mess things up - you probably wouldn't, but you could).  Maybe this is an "ask a high school age friend for a favor" sort of situation.
Posted on Nov 07, 2008
Does the F5U237 work with windows 8.1
It looks like Belkin stop support on certain models of Belkin, even thou you don't state the version model. But if you have a chance, visit this microsoft website which explain that it's not compatible with Windows 8.1
http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20N%20USB%20Wireless%20Network%20Adapter&vendor=Belkin&ModelOrVersion=F5D8053&Type=Hardware&tempOsid=Windows+8.1
Oct 19, 2014 | Belkin (F5U237) 7-Port USB Hub
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Usb device not recognized, works only when plugged on hub
All PCs provides power supply via USB port. The power is controlled by electronic circuit. Sometimes when overloaded the circuit burns out (the last controlling transistor, actually). This does not prevent the data communication, because it is separated circuit. But if the device is not powered it cannot communicate. When you plug the USB device to powered USB hub, then all go right.
Are you able to use the USB ports with other USB-powered devices like USB sticks, mouses, cameras? If not, the mentioned circuit is burned out. If they work OK, then your internal USB hub provides less power current than needed. In both cases there is nothing to do. The circuit resides on the mainboard of the laptop and replacement is expencive. Use it with that external USB hub you have.
Apr 08, 2012 | ASUS G73JH-RBBX05 Refurbished Notebook PC...
USB Hub not functioning
Disconnect the HUB, reboot your PC and connect your HUB again.
Mar 16, 2012 | HP Computers & Internet
My hub cant find drivers
It's a USB hub, it doesn't require any special drivers. Just plug it into the computer and plug in devices. Be aware hubs have very limited suppliable power so if you plug in a lot of devices that use a lot of power and have no power supply of their own you will overload the hub and it will stop functioning.
If the computer is having problems identifying the hub. Go into Device manager and locate any yellow ? or ! devices right click the device, properties and post the status codes.
Device Manger Windows XP Right Click My Computer, Properties, Hardware Tab, Device Manager
Windows Vista/7 Right Click Computer, Properties, Device Manager
Comment if you need further assistance
Aug 17, 2011 | Targus ACH114US 4PORT USB HUB
Dear Sir, Have Dell laptop Inspiron 1525 with Xp loaded....but external mouse is not working with my system but the USB port are working, Sir i need your assistant how do i do with it. Pls HELP...
You will uninstall all the usb universal root hub , and to do follow all the steep.
R- click on My com>Properties>Hardware >Device manager>Scrol the mouse down for select usbhub controller . Now you will uninstall all the usb and restart the raptop again.
If your problem will same ,change the usb MOUSE .
Think it is defected.
Hope it will help you.
Dec 31, 2010 | Computers & Internet
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
I have an Belkin (F5U237) 7-Port USB Hub that is not compatable with windows vista. Is there a fix for this?
if Win7-64 is installing this hub as a "Broadcom Bluetooth Device" or some such nonsense, heres a fix that has FINALLY worked for me...
START > CONTROL PANEL > HARDWARE AND SOUND > Device Manager.
Plug in your hub, and when it pops up under bluetooth radios with an error, right click, then select properties.
Under properties, select the DRIVER tab, then select UPDATE DRIVER.
It should prompt you to choose between "Search Automatically..." or "Browse my computer..."
Choose "Browse my computer for driver software."
It should bring up a location box to search, but there should be an option below the box that says "Let me pick from a list of device drivers on my computer."
Select this option.
This will bring up a list of drivers available.
UNCHECK the "Show compatible hardware" box!!!!!!!
Then browse until you see (Generic USB Hub). Select the first driver on this list and it will work.
The windows generic driver file that works with my hub is in:
C:\Windows\system32\drivers\usbhub.sys
If the above solution doesn't work, you can try to navigate to this specific driver file during a manual installation. Good luck.
Mar 15, 2010 | Belkin (F5U237) 7-Port USB Hub
I am getting error power surge on hub port in windows xp pro
your usb hub is exceeding the power limit or you are attaching a device that is extracting more more , use a USB 2.0 port HUB with a power adapter if you are attaching more devices on hub
Sep 24, 2009 | Computers & Internet
Usb ports
Reinstall your USB drivers:
Navigate to Device manager, find a branch named "USB Controllers" or similar
Right click the one thats the problem (or all of them if you dont know which), select Uninstall
Reboot your machine and windows will autodetect the USBs and reinstall their drivers.
that should work, if not let me know,
thanks.
Check the BIOS and see if they are enabled...
when you start up1.gif your laptop. it will tell you what to press to run setup
Disable power management on the USB hub To preserve power, Microsoft1.gif Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
  1. Click Start , and right-click My Computer .
  2. Click Properties , then click Hardware .
  3. Click Device Manager .
  4. Double-click the Universal Serial Bus Controllers branch to expand it.
  5. Right-click USB Root Hub , and then click Properties .
  6. Click Power Management .
  7. Deselect Allow the computer to turn off this device to save power .
  8. Repeat Steps 5 through 7 for each USB Root Hub.
  9. Click OK , and close Device Manager .
Jan 17, 2008 | Acer Aspire 3100-1405 Notebook
CyberPower CPH720P 7-Port USB Hub Logo
75 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
