Question about Palm Zire 21 Handheld
Hot sync I tried to hot sync my Zire 21 to my home computer and it erased the info from my Palm hand held. I have the info backed up on my work computer so I tried to reinstall it there and it erased my work computer. I did not change any settings until after it erased everything. I use Outlook at work and was syncing to the Palm program at home. Thanks.
  • 364 Answers
Try changing the HotSync settings
Select Desktop overwrites handheld for each conduit
Posted on Mar 20, 2009
Hot sync function does not work with windows 7
http://kb.palm.com/wps/portal/kb/common/article/47831_en.html#zire
Apr 18, 2010 | Palm Zire Mono M150 Handheld
When I hotsynch my palm zire IIIe a message appears telling me that the hotsync operation is complete, but it hasn't hotsynched properly, ie did not add recently added to computer addresses. However, it...
HI,
I had the same problem with my palm. The first thing I did was to make sure I had the most up to date software on my computer. YOu can get this by going to www.palm.com and cklicking on PDA's and then the name of your palm. From there it will bring up a page that has all the up to date desktop software. If you have the up to date desktop software and you have all your information backed up on your computer then preform a hard reset. This will ERASE everything on your palm. If you need directions on how to do this send me a comment and I will get those directions. If you ahve the manual it should tell in there how to do a HARD reset. The hard reset will restore it back to all the default settings and erase it just as if it were new,. After you get to this point do another Hot Sync. It hould sync for you just fine. Hope this works for you. I had great results doing this.
Best wishes.
Aug 21, 2009 | Palm Z22 Handheld
HotSync problem:connection could not be
After you change the battery you need to do a hard reset. This will erase all the info in your pda so you want to make sure you have it all backed up on the palm desktop To do a hard reset follow these steps:
1. Hold down the power button.
2 While holding down the power button, use the tip of the stylus and inset it into the hole in the back of your pda and gently press and release the reset button in the back of your pda.
3. When you see the message that warns you about erasing all of the info on your hand held select continue.
4. When prompted follow the online directions to align the screen. After that you will want to do another hot sync. Best wishes.
Aug 10, 2009 | Palm Tungsten E2 Handheld
Hot sync
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(2630)
With your Palm Zire 21 connected to your pc, go to the link above and run through the Palm HotSync troubleshooting dialog to see if any results come up that will solve your issue.
HotSync issues are unfortunately difficult to pinpoint and often will require a software update or patch to resolve issues.
Good luck with it!
OpenSource13
Apr 08, 2009 | Palm Zire 21 Handheld
I want to delete a user on my zire31 pda
You should be able to hard reset the palm and erase all data. There should be a rest pin hole on the back, hold it and press the power button. All internal memory will be erased.
Mar 17, 2009 | Palm Zire 31 Handheld
Hotsync
do you want to completely delete all the data on your palm zire if so try a hard reset (deletes everything!)
To do a hard reset:
Press and hold the power button on the front panel of the handheld.
1.
While holding the power button, use the tip of an unfolded paper clip (or
2.
similar object without a sharp tip) to gently press and release the reset button.
Wait for the Palm PoweredTM logo to appear; then release the power button.
3.
When a message appears on the handheld screen, warning that you are about
4.
to erase all the data stored on your handheld, press any other button to perform a soft reset.
Mar 16, 2009 | Palm Zire 21 Handheld
I have a TungstemE2. I cannot find my addresses. I am on an apple MACBOOKPRO. My hand held works, but the computer file doesn't respond. Actually it did for a minute in very funny type and unsorted by...
Hi----- hope this works--- you might need new update software.
  1. Download Palm Software installer (.dmg file)
  2. Ensure you are logged in to your Macintosh as a user with Admin privileges.
  3. Double-click on the PalmSoftware installer file.
  4. Enter your Administrator password when prompted.
  5. Install or renstall Palm Desktop. Note: There is no uninstaller included.
What is this software? This software lets you sync your Palm device with your computer, so your info is backed up and easily editable on your computer.
Keep your information up to date wherever you are. When you sync, any changes you've made to Calendar, Contacts, Tasks and Memos are automatically added to your computer or your Palm device.
Palm Desktop is the desktop personal information manager. HotSync Manager controls synchronization. Both are included in a single download on this page.
If you sync with Microsoft Outlook or Entourage, you still should install this software.
System Requirements Palm devices
  • Tungsten C, E, T3, T2, T, W
  • Zire 31, 21, original Zire
  • Palm i705, m500 series, m100 series
  • Palm VII series, V series, III series, Pilot series
  • Zire 72, 71 (only if you have Mac OS 9)
Mac versions
  • Mac OS X (version 10.1.2 or higher)
  • Mac OS 9 (version 9.2.2 and higher)
Computer
  • 25 MB free hard disk space
  • One available USB port for synchronization
PowerPC and Intel Core Duo Palm Desktop and HotSync Manager software works with both of these processors. We have found no significant new issues using our software with the Intel Core Duo processors found in Macs such as the MacBook Pro.
How To Install Before you begin:
  1. Be sure you are logged in to your Mac with admin privileges. If you're not sure how to dothis, refer to Apple support.
  2. Keep your Mac's admin password in mind. You'll need to enter it during installation.
Download & install:
  1. Download the file and double-click it (PalmDesktopMac421Revd.dmg).
  2. After your Mac mounts the file, a new icon named palmOneSoftware.pkg will appear in the same location. Double-click this item.
  3. The Palm Desktop installer wizard will begin. Follow the onscreen instructions to install Palm Desktop on your Mac.
  4. When installation is finished, you may drag and drop the palmOneSoftware.pkg item to the Trash, or archive it on your Mac hard drive for future reference.
Jan 22, 2009 | Computers & Internet
Palm Zire to itouch
Those two devices are not compatible to one another. You may get it to work by exporting the Palm desktop data into a CSV file and importing it into the program you use to sync the Itouch with.
May 22, 2008 | Palm TX Handheld
Lost data on palm zire 21 hand held
To the best of my knowledge, if you don't have a pc backup, you are out of luck.... Sorry to be the bearer of bad news... Download the Palm Desktop Software and start to use it if you decide to continue using the Zire 21. The Software is free from Palm.
Sep 25, 2007 | Palm Zire 21 Handheld
Palm Zire 21 Handheld Logo
148 people viewed this question
Top Palm Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
