Question about HP PSC 2175 All-In-One InkJet Printer
Says clean carrage jam nothing jamming it - HP PSC 2175 All-In-One InkJet Printer
  • HP Master
  • 17,129 Answers
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Remove printer , uninstall software ,then reinstall and connect printer.
Posted on Oct 09, 2010
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Carrage jam
paper in the printer still open and look
Apr 25, 2012 | HP PSC 1610v All-in-One Printer
PAPER JAM / CARRAGE JAM
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
Carriage jam
change the carrage block.this error is comin because of faulty carrage cable
Aug 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
CARTRIDGE JAM - CARRIAGE JAM - PAPER JAM - RESET POWER
change the carrage block will solve this issue.the carrage block cable is damaged
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Carriage Jam
If either a paper jam or blocked carriage error message appears on
the control panel display, there might be some packing material inside the HP allin-
one. Lift open the print-carriage access door. The orange shipping lock might
still be in place on the left side of the HP all-in-one. Pull out the orange shipping
lock and throw it away
Jan 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
I keep getting an error (81:01)
The problem refers to basically a paper jam. I thing your problem could however be the carrage movment. There is a special oil required for the carrage, but failid this use a very thin oil such as sewing machine oil. The trick is to not use too much oil, only a drop or two over the entire length of the carrage. Also needs to be oiled is UNDER the rail towards the back. Look carefully at the back of the carrage where it has the back slider. This rail needs to be clean and lubricated. Probable easier to clean and lubricate if you remove the encoder strip.
Regards
Dave
Dec 10, 2008 | HP DesignJet 500ps InkJet Printer
Tape jammed
sorry guys/gals problem was mechanical the riser carrage had jammed so used a big srew driver and mallet to get the tape out unscathed so problem solved thanks anyway.
Aug 17, 2008 | Canon Video Cameras
HP PSC 2175 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
