SOURCE: Aloha breeze tower fan can
The one I have can. Pushing the comfort control button will cycle from cool, to low heat, and then to high heat and then back to cool.
SOURCE: How do I run the tower fan?
Plug it in...push the power botton. If you don't know which that is, hit them all until you feel a cool breeze.
SOURCE: I have an Aloha Breeze
I couldn't find anything either and then my husband calling them. There is a number in operation manual but they are close right now. Here is the number 1-800-295-4448.
SOURCE: Aloha Breeze Tower Fan Will Not Oscillate
hi,
yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
good luck
J
SOURCE: how do i clean my tower aloha breeze fan
you have to remove the fan housing. it is usually screwed.
