Question about Konica Minolta DiMAGE Z5 Digital Camera
Hi I have a minolta Z5 and the lens will not go back in when it is turned off. also I can not zoom in or out with the lens. I have tried everything regards ray
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 09, 2010
I have a minolta MD lens 35-70mm f3.5 that is stuck at 70mm. how do i get it unstuck?
Hi!
Is your lens having a "macro 1:4 - 1:7" green sign near the "70"? If it does it may be stuck in the macro position... ? To put it back into the normal "35-70" zooming position just press the little black and greenish button on the lens, turning the zoom anti-clockwise.
Well... i'm Italian and tonight my english is particularly stuck.. But I hope this could help you!
Let me know, cheers :)
Emi
Feb 02, 2011 | Cameras
Camera won't stay on, even with new batteries that I know are charged.
Ensure you are using alkaline batteries and that battery contacts have no oxide or liquid on top of them. If you do not use alkaline batteries this is normal.
If batteries are ok is a short circuit.
Jul 29, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
System error appears over my pics when in viewing mode and camera shuts
Turn the camera off, remove and reinsert the batteries, or unplug and reconnect the AC adapter.
Also, what is the capacity of the memory card you are using? If its 4gb, you will have an issue with the system error.
How long have you had this camera by the way?
Jun 10, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
Faulty zoom
try to reset factory setting
Sep 18, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta DiMage Z5
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
ANTI-SHAKE TURNED OFF
  • Switch camera on
  • Select Menu Button
  • Menu item 1
  • Use controller to move down to anti-shake
  • Use controller to move right
  • select i) Disp + Exp ii) Exp only iii) Of
Go to http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z5/Z5_OM_E_.pdf for a Z5 manual
Jan 26, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
HELP!!!!!
Does the barrel fully retract when the camera is shut down? I suspect a mechanical problem... If you're not very technical, I do not recommend opening it up... Try whapping the objective a little. I'm not kidding; the problem may be caused by some gears that got stuck... Otherwise, it could be quite hairy because the zoom motor or its controlling electronics could have gone bad...
Feb 09, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Dimage Z5 lens and screen problems
Minolta has been bought by Sony and they're very tight with parts for repair. Unfortunately, it'll have to be repaired by Sony. Go here for details: http://eservice.sony.com/webrma/web/index.do
Dec 18, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE Z5 Digital Camera Logo
177 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
