Question about Garden
I need to replace the deflector on my Mountfield Princess 14 electric lawn mower ... but not certain how to do it. Do I need to take the red top casing off, and if so what tool do I need to get the bolts off. They look like 1/4" (across the flats) hexagonal bolts, but an ordinary spanner won't do it as the bolts are inset into the casing. Also the handle will prevent any tool longer than 3" from getting onto the bolt in the first place.
5 Suggested Answers
jgr4
  • 9 Answers
SOURCE: In need of a replacement handle
Look for replacement parts at http://www.reelin.com.
You can find some owner's manuals, with part numbers, here:
http://www.reelmowersetc.com/
Posted on Jul 14, 2009
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
co7196
  • 3433 Answers
SOURCE: Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
Posted on May 26, 2010
  • 111 Answers
SOURCE: how do i replace blade on mountfield princess lawn
It should be a standard thread. You may need to put a shop rag into the spark plug hole to make sure the engine does not turn while you are trying to remove the blade.
Posted on Mar 30, 2011
Testimonial: "Thank you for your help it was much appreciated, did the job of replacing the blade with no trouble thanks again."
Mountfield Mower is chugging.
Excess air. Remove clean or replace air filter.
Jul 12, 2013 | Garden
Replacement blade for castelgarden C390 lawnmower
What Geographic location please?
UK:
http://www.ebay.co.uk/itm/Mountfield-Castel-Garden-EL390-R-C390-K390-Mower-blade-/280561700508
The blades on most sites are listed under Mountfield / Castel / Lawn King
There are 41cm and 37cm blades listed as fitting this mower. Seems odd that there is a 4 cm difference for the same mower.
As best I can tell this takes a 15 inch blade PN: 81004117/1 (
http://www.gardenhirespares.co.uk/product_list/81 See 15 inch blade
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | OEM Replacement Parts Lawn Mower Blade...
How do i replace blade on mountfield princess lawn mower. is it a left or righhand thread
Mar 28, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Mountfield mower manual
it seems this mower is made by Homelite with the Mountfield name on it.
May have to see if you can locate a source for homelite to find this manual.
cheers
Sep 26, 2009 | Garden
I need onwers manual for Mountfield Laser Delta mower
Have you Contacted Mountfield about a Manual? You can Contact them Using the Options at this Site Addy;
http://www.mountfield-online.co.uk/contact?jssCart=13a24ca4de2a2610f7213de8a0539ffb .
For an Engine Manual you can Contact www.outdoordistributors @ 877-707-2787 or Contact Tecumseh @ 800-558-5402.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
