Question about Makita 7 1/4" Circular Saw 5007NB
I just purchased your Mod 5740NB circular saw. I have used it a few times and now the on off switch does not work. If you plug it in it runs and will not respond to the trigger. I own a lot of Mikita tools and this is the first time I have had a problem. I live in the north and it is very difficult to get service unless I use the mail or Purolator. My address is 108A Hopkins Bay Road, Iron Bridge, Ontario. P0R 1H0. Phone 1-705- 842-6135. Any help would be greatly appreciated. Thank You David Ratz
    Problem Solver:
  • 8 Answers
I have three of these saws and have had the same experience but only after hundreds of uses and it's kinda expected. Since this is a relatively new saw try (with it unplugged) pull the trigger and slide your finger to the side allowing it to snap back. Try this a few times if you do need to replace the switch, order the part and do it yourself, if you can operate a saw and you still have all the at the end of the day, this should be a job you can handle. If it's still under warranty you'll have to send it in.
Posted on Oct 09, 2010
My Makita circular saw won't turn off. What can be causing this?
You could check the switch prior to buying and fitting a replacement with a simple circuit tester. (Statically with the power off). Unless you have shorted wiring around the switch, which is highly unlikely, I would say that a new switch will do the trick. Cheers Bob
Nov 05, 2016 | Saws
Why won't my 14 amp, 7 1/4 in circular saw turn on?
check for the safety switch that you have to press while pulling the start switch
both switches have to work in the on position or the motor will not run ( safety requirement)
Nov 23, 2015 | Saws
My circular saw is not working
Check brushes...
Dewalt Craftsman 2 Pack Carbon Brush Holder for Saws 147097 09 2pk
or sometimes the switch fails...
Craftsman 7621301 Circular Saw Switch
if you luck out, it may just be a broken wire, right at the switch, or right where it enters the saw? Pulling the, or directly on the cord vs. just the plug puts a lot of strain on the wires.
But if it is one of the parts above, very easy repair.
Apr 13, 2015 | Craftsman 7 1/4" 12 Amp Skill Saw
Ryobi 7-1/4 in. laser circular saw will not turn on when it is plugged in.
Same problem with mine but I.found a guy's blog on google and he had identical problem and found the "pre travel switch," that they saw fit to put in the saw was the culprit. It's not a typical switch and has issues making contact often times (Ryobi are you listening?) He was able to take it apart and make a adj/repair (instructions he provides on blog) but who knows how long it will last? Here's the link:)-> http://www.woodtalkonline.com/topic/9508-ryobi-circular-saw-broken-and-fixed/
Dec 17, 2011 | Ryobi 7 1/4 In. Circular Saw W/ Dual...
No power when i squeeze the trigger on the hd77
Troubleshoot the problem. It could only be a few things: 1) defective trigger/switch, in which case you can replace it by getting the part from a specialty tool store; 2) the cord itself, either where it plugs into the saw or at the plug end there may be a loose wire; 3) you've accidentally cut or nicked the cord--easily done--and there is a severed wire.
Jul 31, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
First time using, plugged in, power light/laser works. Saw will not turn when pressing trigger.
Same problem with mine but I.found a guy's blog on google and he had identical problem and found the "pre travelicon1.png switch," that they saw fit to put in the saw was the culprit. It's not a typical switch and has issues making contact often times (Ryobi are you listening?) He was able to take it apart and make a adj/repair (instructions he provides on blog) but who knows how long it will last? Here's the link:)-> http://www.woodtalkonline.com/topic/9508-ryobi-circular-saw-broken-and-fixed/
Feb 26, 2011 | Ryobi 7 1/4 In. Circular Saw W/ Dual...
When i press the switch of the saw it starts then immidiately stop after few seconds
After never using for 6 months, I finall had the need to use my Ryobi saw and had the same problem. Push the switch and it would make one revolution and die. I took the blade off and the end cover oppsote end to epose the other end of the motor shaft. Applied small drop of oil to each. Continued to play with trigger and finally got the motor to get running. Held it on for several minutes. I had to do this several times in order for it to start working properly. Might ne something with breaking in the brushes. Regadless, it works now. Give it a try. Be patient.
Dec 04, 2009 | Ryobi 12v Lithium-Ion Cordless 3-3/8"...
Makita 6410 petrol disc cutter
First of all, make sure you have followd the correct start up procedure.
(1)Throttle on and locked in start position, (2)choke on and pull a few times. Saw should fire briefly and cut out. (3)Now switch to idle (half choke if applicable) and pull another couple of times. Saw should now fire and run. If you have pulled it too many times in the full choke position you will have flooded the engine. To rectify this you will need two people. One of you should hold the machine steady on the ground with no choke on and throttle fully open. The other should also steady the machine and pull the starter in quick succesion. This could take ten or so pulls but it should start the engine in the case of flooding. Sometimes it will splutter a couple of times before fully starting and it will normally bog down a bit for the first few seconds as it spits out the excess fuel/oil mix.
If you got to point (3) as it shown above, and then the saw wouldn't start, or hadn't fired and died then there could be a few different problems. basic checks are for, clean filter, fresh/clean fuel, clean spark plug (ie, not oily/choked with carbon build up). When checking the spark plug, if it has fuel/oil mix on it then ther is probably aeither a compression problem/air leak or no spark. To check for a spark leave the plug unscrewed but fitted into cap, rest it against a metal part of the saw and pull the starter with the elec switch on. You should see a healthy blue spark. WARNING, do not rest the spark plug near the plug hole as if it does spark it could ignite any fuel/oil mix that is pumped out of the cylinder. I've had many a singed eyebrow from this happening. If there is no spark, check to make sure the cap is attatched securely to the lead,and try repacing the plug. If this doesn't help you will need to get the coil, ht lead and wiring tested.
Oct 15, 2008 | Makita DPC8112 16" 81CC Gas Powered Power...
Makita 7 1/4" Circular Saw 5007NB Logo
76 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
