Question about Whirlpool GHW9100L Front Load Washer
Sears gave me an estimate of $1439.65 to repair machine by replacing the following: 1 SUB TUB-OUTE - 213.82 1 GASKET - 12.16 1 SUB TUB-OUTE - 411.91 1 SUB BASKET - 492.69 1 BELT - 25.94 + LABOR 193.50 This seems outrageous to me. It is only 8 years old and they want more to fix it than it cost me to buy one brand new.
Check your warranty. We just had that problem, with the exact same parts replaced, but the outer tub has a ten year warranty, and the basket a lifetime warranty. We just paid labor and for one belt. Our washer is also almost eight years old.
Posted on Oct 15, 2010
LEAKING SOAPY WATER
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
May 20, 2010 | Kenmore 22622 Top Load Washer
Black debris particles sticking to clothes
It's very un-likely that the Motor Coupler can cause black spots on clothes. It's far enough away from the tub and basket that even if it were wearing, the black rubber would drop to the floor instead of moving up.
It could well be the gaskets in the outer tub.
See the following:
Depending on the problem (likely gasket) it's certainly less expensive than calling in a repair person and gives you a chance to thoroughly clean the washer.
While you have the washer apart, it might be a good idea to replace the motor coupler again. (A $15 - $20 part)
Apr 30, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore is 11 years old, it is leaking water on the floor.
I didn't see your complete problem description but I assume it has to do with some sort of leak.
See the section for the basket and tub assembly's. You should also see the parts and Sears prices.
See the following:
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
If this is a basic top load, direct drive machine, from a repair viewpoint, these are very good machines and relatively easy and inexpensive to fix.
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Water leaks under the washing machine Kenmore top loadin washer, model 110-234642300
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet and gain access to the pump.
newsPath=16&newsdesk_id=134&osCsid=b547cd9bb24b4ffaef51e860554a9cb0
Check the areas for the motor and pump and the Agitator Basket and Tub.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Jan 11, 2010 | Kenmore Washing Machines
My Whirlpool Cabrio sounds like a jet engine while in the spin cycle
believe the bearings can be bought locally,but water seal has a Whirlpool number on it that will not come up on pricelist on my Whirlpool program.I am looking for a way to cross ref. this seal and repair the tub.The last tub was over 197.00 cost for new tub and drive shaft ,bearings and seal.The bearings are Korean made and can be bought locally for alot less than a whole new tub.This is an ongoing problem with the Cabrios and Maytag Bravos that I have seen lately.Also a few of the Sears Kemores out there.There has to be an easier and cheaper repair for these thousand dollar machines.I dont like telling the customer its going to cost them 400.00 to repair their washer when it is not even a year out of warrentee.If anyone has the seal number or a cross number please post
Nov 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Inside the washing machine "tub" there is a black scummy ring at the top....can't get rid off. Seems like its a rubber ring that is disintegrated.
If you look at the section for the Agitator and Tub, you should see a part called the Tub Seal. This could be what is disintegrated.
See the following for how to remove the cabinet and Tub Ring in order to get to it.
Sears has part numbers for either the complete tub ring and gasket or just the gasket.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0c973faf3f16f7a1164288d4e610c748
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Have a 110.92380200 top load washing machine. replaced 3 suspension springs and 1 counterweight spring. not sure where the counterweight spring goes? I do know one side hooks to the rear bracket on which...
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The sections on machine base or tub should give you a decent diagram of where the springs go.
Sep 09, 2009 | Kenmore Washing Machines
Sears Kenmore Front Load Washer model number 41742052100
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Kenmore Washing Machines
I have a front load washer model #44832. We had a
FREE??
The unit is not under warranty.
Mar 05, 2009 | Kenmore Washing Machines
Sub Pully has wore to the point it allows the belt to slip off
Cliff, I think the tub and basket have a five year warranty on them. If the technician thinks they need replacement, then the warranty should cover it. Should be a labor only deal...Catriver...post back.
Mar 22, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
145 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
