Question about HP Photosmart D5460 InkJet Printer
When I turn the printer on in the display it says Missing or Damaged Cartridges I have removed them and cleaned them but no joy
  • HP Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Posted on Oct 09, 2010
Ink printer cartridge replacement
The error code you have 1401 shows 'There is no print head installed' With the printer turned off and unplugged: Remove the printer cartridges. Check to make sure the contact points are clean and do not have something covering them. Look inside the printer and check the cartridge bay for any debris or dust blocking the connection. If anything is found clean gently with a q-tip or cloth. Do not touch the contacts with your fingers. Reinsert the cartridge and power on the printer. If the same error code displays return the print cartridges for a replacement as they may be defective. Most cartridges have a chip on them that communicates with the printer. If the chip is missing, damaged it will not work. As always only use manufacturer recommend cartridges.
Dec 01, 2013 | Canon Office Equipment & Supplies
HP 6500 ALL IN ONE DISPLAYS ERROR ON SWITCH ON Ox61011BED
Hi Norman,
The Error message usually relates to Printer Failure. However you can try few steps to fix it. ( Hopefully )
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges and Printhead ( Printhead is the part on which you install the cartridges )
3. Lift the latch to remove the Printhead.
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the printhead with lint free cloth. ( Golden dots at back of Printhead )
6. Turn on the printer and it should say " Printhead missing or not installed/Damaged "
7. Install the Printhead and Cartridges and close the latch and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Jan 29, 2013 | HP OfficeJet Office Equipment & Supplies
Hp 7500a "The following ink cartridges appear to be missing or damaged"
clean the gold contacts where the ink cartridges seat with alchol and microfiber towel replace ink cartridges.
Jan 21, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Not sensing the ink cartridge
In this scenario you should check with a new set of black cart or you can try by cleaning the cart with a lint free cloth. and try with resetting the printer as well. if it doesnt work then printer might have gone bad
Oct 21, 2009 | HP Photosmart C6280 Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
HP Photosmart D5460 InkJet Printer Logo
193 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
