Question about CDA CI392 Front Load Washer
Washing machine CDA C1330 flash F8 - CDA CI392 Front Load Washer
2 Suggested Answers
  • 6277 Answers
SOURCE: please email manual for CDA
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 04, 2011
My Cda washing machine is showing f02 fault code
CDA WASHING MACHINE CI931IN SHOWS FAULT F02 ..not sure if this is your model..when you go to this page just scroll down the page and you will see what you need to read.do not fill any thing in.
Nov 20, 2016 | CDA Washing Machines
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
Cda c1330 washing machine
Fixya does not advise purchase sources.
Sep 01, 2017 | Washing Machines
Please email manual for CDA C1330 washing machine as fault code keeps appearing
John C.
Jul 04, 2011 | CDA CI392 Front Load Washer
My cda washing machine keeps flashing up code FO4 and it is failing to start can you help?
Do not know your model number but give this a try .erase the flashing LED . hold the start button in for 2 seconds this should reset the machine . unplug from wall wait 5mins and try again .
Feb 22, 2010 | Washing Machines
My c1392 cda washing machine, firstly stopped spinning and then smoke appeared?
oow, that sounds like the motor has just poped its clogs you may find that fitting a new motor is hardly worth it,,,sorry
Jan 17, 2010 | CDA CI392 Front Load Washer
CDA C1930, F02 APPEARS
If the F/02 error shows, it indicates a "long drain"; If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press the PAUSE/CANCEL button twice to clear the display and verify the following:
  • Verify that the drain hose is not plugged or kinked.
  • Verify that the electrical connections at the pump are good and make sure the pump is running.
  • Verify that the drain pump filter has not collected any foreign objects.
If none of the above corrects the problem, unfortunately you will need to replace the pump.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 22, 2009 | CDA CI392 Front Load Washer
CDA BI 1200 WD
It could well be the brushes on the motor, take them off and check them (ensure spring still intact and both are making good contact), put them back in, if it begins to work then it'll be the brushes not contacting porperly.
Oct 23, 2007 | CDA CI392 Front Load Washer
CDA C/392
you should e-mail service@cda.eu or contact them through their site; http://www.cda-europe.com/docs/CCD_Home.htm Hope this helps :)
Jun 25, 2007 | CDA CI392 Front Load Washer
CDA CI392 Front Load Washer Logo
187 people viewed this question
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
