Question about Clarion DXZ945MP CD Player
Removing Clarion DXZ945MP and installing Clarion FZ709. Just need wire colors for illumination lead mainly. Going to reuse harness adapter currently wired to DXZ945MP. Want to double check wire colors same out back of DXZ945MP and FZ709.
5 Suggested Answers
SOURCE: Installation
I already have that
Posted on Feb 14, 2008
SOURCE: insallation
I got it figured out all I had to do was run my remote wire to the power thriugh the fuse box
thanks
Posted on Feb 15, 2008
kenw392
  • 2226 Answers
SOURCE: What voltage do i connect
you don't really need to connect the illumination wire up at all. if the display is not lighting up, you have a problem in the radio.
Posted on Nov 02, 2010
ZJLimited
  • 17970 Answers
SOURCE: where can i find a
Check in this link for DXZ945MP_Manual (pdf)
Hope this helps (remember to rate this answer).
Posted on Mar 02, 2011
How to install a Clarion CX 400
all you will need is a wire harness adapter from a audio store or ebay ect. just put in the year of your vechical and it will show up with the harness that will work for your car all wires are color coated for easy setup good luck
May 03, 2014 | Clarion CX400 Car USB Player
Tip
Clarion DXZ945MP Manual Download
Download Clarion DXZ945MP Manual
Have you misplaced your Clarion DXZ945MP Owners Manual?
Would you like a digital, searchable, pdf version of the Clarion DXZ945MP Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 23, 2010 | Clarion DXZ945MP CD Player
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Have original wiring harness for biuck rivera 96 need to hook upto clarion harness having trouble with colored wires which goes where
Most auto parts stores sell plug in harness adapters per vehicle, it make installing a stereo very easy and cheap only about 10.00 dollars
Nov 11, 2009 | 1996 Buick Riviera
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
I cut my leads of wiring to my car to connect radio. they were cut to short reconnect what can i do
You didn't say what kind of car, however most cars now have a connection plug for the wiring, see if you can see that if you can and can unplug it you will have two options. 1 you can connect your wires outside the car and hope you have the length to plug back in or 2 you can go online and buy a wiring harness for your car that will come with instructions and plenty long wires (easiest)
Aug 18, 2009 | Clarion DXZ945MP CD Player
Matching wires from Seaworthy Marine Radio to Clarion M109
yes you dont need the orange but the yellow in the main power red is the iginition.
Jul 23, 2009 | Car Audio & Video
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
I just installed a Clarion max385vd. When we turn the headlights on, the buttons and screen illumination on the head unit keep flashing from dim to bright. Everything else is working perfect.
illumination wire does not need to be installed on this model. depending on your car, it may use odd voltage for the dash lights. Clip and tape off the illumination wire going to the harness.
Dec 26, 2008 | Clarion MAX385VD Car DVD Player
Installation
i suggest getting a wire harnees kit from an auto supply shop{pep boys,autozone,)the wire are usually color coded.also try going to to clarions support site they probably have a diagram 4 u.if not get back to me and ill tell you how to test and discorer what wire is what.if you connect wrong wire you can burn out your radio
Jan 21, 2008 | Clarion DXZ945MP CD Player
Clarion DXZ945MP CD Player Logo
105 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
