Question about Jensen Car Audio & Video
Jensen cs4000 cassette/radio from the 80's. How do I set the digital clock? It starts displaying and counting from 1.00pm when the 12V supply is connected.
  • 135 Answers
SOURCE: setting clock
Try this (it is from the instructions for a similar model): The URL for this manual is:
Posted on Mar 31, 2007
SOURCE: Setting the clock on a Comdial DX-80 Digital phone
To change Comdial phone read out time
######## (8 pounds)
save (System time)
show (Year)
next (Month)
next (Day)
next (Weekday)
change enter what you want to change
Posted on May 22, 2009
  • 518 Answers
SOURCE: clarion arb1170 cassette player
Posted on Jun 13, 2009
  • 814 Answers
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
SOURCE: FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Posted on Jul 27, 2009
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
Mar 02, 2016 | Jensen Interactive AM/FM Talking Dual...
Jensen jbd-100 change clock
Take battery out and unplug to force a reset.
Hold Display until it starts flashing 12 hr
----use tuning buttons if you need to change that to 24hr
Tap Display to confirm setting and move to next stage
Repeat the same steps of tap Display and then use tuning to adjust up or down for the hour and minutes.
Make sure to increase hour setting enough to have the "pm" show up for times after noon when using 12 hr format
Nov 06, 2013 | Jensen JBD-100 UNIVERSAL BLUETOOTHR CLOCK...
I am not sure how to set the time interval in the nap mode. It starts at 2 hours, and I can't change it.
Ok, this is the way it works, and I keep my clock radio for this feature alone. It is a 2 hour "count down" timer. It is set in 15 minute intervals. Supposed you wanted to take a 1/2 hour nap. Press the button but don't let go. As you hold your finger down the timer will start at 2 hours (2.0) and it will then go to 1.45, etc. When you get to a 1/2 hour let go and it will start counting down. If, in the process, you make a mistake, press the blue button and don't let go. Hold it down until it erases the setting and removes the NAP text from the front display. Release button. Start holding down the button again. Once again, the display will go to two hours, continue to press button, it will start counting back in 15 minute increments. Again, when it gets to 1/2 hour, quickly let the button go. As the clock counts down, you cannot see how much time is left on the clock. Press the button, quickly let go again. It will display how much of the 1/2 is left. When the clock counts down to zero, either the alarm will sound or the radio will start playing depending on what you set the alarm to do. Press the off button, that's it... (0:
Sep 01, 2011 | RCA RP3721 Clock Radio
I don't know how to set the clock on the jensen jbr550 radio in my bus
To set the clock, turn the radio on in tuner
mode (or any other mode).
Press D. The time appears on the display.
Press and hold D until the time display
begins flashing.
While the display is flashing, press the Up
Tuning button to adjust hours and the
“A” (AM) or “P” (PM) indication. Press the
Down Tuning button to adjust
After five seconds, the time will set and the
display will return to tuner or CD display.
Aug 18, 2010 | Jensen Car Audio & Video
I bought a car with this model, 6cd/cassette
Setting the clock:
1.Press and hold the Band Button (on the left of radio)and the Clock setting button (button No:4 on the right) to display the clock.
2.Press and hold the Band button and the Clock Setting button again for 2 seconds or longer for the clock display adjustment.
3.Press the SEEK UP Button (on the right of the radio with the arrows) to set minute.
4.Press the SEEK DOWN button to set hour.
5.Press the Band button to confirm the clock setting.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 25, 2009 | Clarion ARX6670Z Cassette Player
Clarion arb1170 cassette player
May 04, 2009 | Car Audio & Video
How do I set my clock on a Jensen cm 715k
Push Display to go to the clock. Next (within 3 seconds)press display again. the Dots will flash. push << or >> to change. See link- Installation
Apr 29, 2009 | Jensen CM715K CD / Cassette Player
Setting clock
Turn the power on. Push and hold the DISP button. Then use the volume button to change the time.
Nov 06, 2007 | Jensen CM9521 CD / Cassette Player
Need to set the clock
press CLK button to temporily display clock to set clock press clk > 2 sec use the left and right arrow to set hour and min
Aug 22, 2007 | Jensen KDC-9520 CD / Cassette Player
Car Audio & Video Logo
62 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
