Question about Home
I HAD BLOCK MY TV SHARP 51AT-15S BY ENTERING CODE BUT I DIDNT REMEMBER CODE AND I CANT OPEN MENU?PLEASE HELP ME
SOURCE: Sharp 56DR650 service menu
Hold menu & vol+ (for 3sec) opens the lamp counter reset menu on Sharp DLP
press OK to reset
Dan
XPortHomeNetworks.com
Posted on Aug 16, 2008
  • 4 Answers
SOURCE: sharp 19"color tv
change the electrolytic capacitor in the high voltage section.and check the continuity if there are open resistor.
Posted on Sep 07, 2008
tehnik_bdg
  • 91 Answers
SOURCE: Sharp 5316E how to enter code
Did you mean the account control code ( 3 digits code ) ? If you forget this code, either you disable the account control mode or change the old user accounts. Here's how :
1. Enter the USER MODE PROGRAM by pressing and holding the Light key indicator ( the white half circle ) at the bottom left of the machine.
2. After the all the lights at the panel goes off ( except the quantity copy display, it will show 3 lines ). press 10 with the 10 key and START, change the value from 1 to 0 and press START again to save the value. THIS IS DONE TO DISABLE THE ACCOUNT CONTROL MODE.
3. If you want to show the user account and cange it to a new account, repeat the above step but enter 12 instead of 10 and press START. It will shows you your current user accounts ( up to 20 accounts ). If you still want the old user account, remember that code and press the light exposure key 1 more time withou holding it.
4. If you want to change the old user accounts, after the machine shows you the user acccount press START and input the new 3 digits code and START again.
Posted on May 27, 2009
  • 1126 Answers
SOURCE: cant program
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&kw=&st=&ar=&dt=&so=&au=&le=&pg=1
This is the closest I can locate...however I didn't see your exact model number listed.
Posted on Jul 21, 2009
darkdragons
  • 835 Answers
SOURCE: cant remember code for remote
Here is a huge list of Philips universal remote control manuals. You can hopefully chose from the list the exact one you got.. How ever if you cant, then don't be afraid to look at some of the others manuals. Companies such as Philips keep the same codes for almost every remote, that way when its customers upgrade to new ones, they can do so with comfort and ease cause most will already know their code form the old one.
http://tv.manualsonline.com/manuals/mfg/philips/philips_universal_remote_product_list.html
Please rate me, give feed back, recommend me if you thought I was helpful. This will not only help me to know how im doing, or if i need to improve, but also help others decide if i could be someone that can help them.
Posted on Oct 03, 2009
Testimonial: "thank you!!! great help for a simple mind like me!!"
Sharp tv lc 32sh12u menu
Just open the menu by using the universal remote control, and do the rest by using Up/Dn & Left/Right buttons at the the TV front panel.
Jan 29, 2013 | Sharp LC-32SH12U TV
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Tv remote not working
are you entering the correct codes for this TV?
Try these one is bound to be the one you need
Sharp
0093 0165 0386 1193 0157 0036 0294 0491 0653 0053 0256 0193 0186 0516 0200 0760 0818 1917
on most universals you selct TV + SET a light comes on either steady or flashes enter the code, light goes out PRESS SET again then try turning TV off/on if didn't work, try next 4 digits until you find the right one.
Make a note so you can remember it next time. Be aware that sometimes if the DVD is pressed the TV wont appear to work.. just selct TV and then press on/off and it reverts to the saved code. It hasn't lost it just that you moved the selection to another device.
Please rate my help++++Thyanks for using FIXYA
Jun 11, 2010 | Sharp 20F650 20" TV
I cant find the 4 digit of the one for all remote control model urc 1030b04 for a sharp tv
I can help you with your URC-1030 Universal Remote Control issues.
The URC-1030 codes for Sharp TVs are: 0093, 0165, & 0688.
For complete instructions on entering the URC-1030 remote codes, please refer to my posted Fixya Tip One For All URC-1030 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-1030 Manual
One For All URC-1030 Code List
One For All URC-1030 Code Search
One For All URC-1030 Reassign Key
May 13, 2010 | One For All URC-1030 Remote Control
Removing parent block on a used Toshiba 36HF73 36
If you don't have the unlock code you can do this to remove it. Please take a few moments to rate my answer..Thank you...
If you cannot remember your PIN code
While the PIN code entering screen is displayed, press RECALL
four times within five seconds. The PIN code will be released
(Blocking Reset status restored)
Nov 17, 2009 | Toshiba 36HF73 36" TV
REMOTE CODE FOR SHARP TV MODEL 51AT-15H.
You can find the codes for Sharp TVs in this document:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021
Nov 12, 2009 | One For All URC-3021 Remote Control
I ACCIDENTLY SEEMED TO ENTER A CODE TO BLOCK CHANNELS IN MY TV SET AND NOW DO NOT REMEMBER WHAT THE CODE IS? IS THERE ANYWAY I CAN RESET?
To reset/clear the password for the LC-32SH12U TV, PRESS and hold both VOL-- on the TV and press 0 on the remote control simultaneously for a few seconds until (LOCKS) menu appears on the screen.
Now the old password was cleared. You can set the new password.
May 28, 2009 | Sharp LC-32SH12U TV
I have a mitsubishi cs-26ex1 tv and the parental code is set but I dont have the original remote or a user manual to reset the code. How can I unlock the tv?
well first lets narrow this down so the tv is already holding a code you will need the old code to re-enter a new 1 okay if the code is known you may be able to set with the menu button goto pc option try to use the channel up and down and volume see if this will help now lost remote may try a universal remote make sure it has the menu option on it ,also when entering code numbers some have over 5 or so codes okay the tv may respond to 1 code but not let you use the menu so try each code also if you cant remember the code its not to good you will have probally no choice to take to tv shop okay good luck shad
May 06, 2009 | Televison & Video
Need Codes
The Sharp TV codes for that remote are 0093 0165 0688
The dishnetwork code should be 0775
Let me know if you have any problems. Thank you for using Fixya!
May 12, 2008 | One For All URC4220 Remote Control
Remote set up
i need a code for my remote control to turn the sharp tv on i also have a dvd by jvc ,vcr by magnovox will the same code work on all the equipment
May 04, 2008 | One For All URC-3021 Remote Control
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
