Question about Parkinson Cowan SG556 Gas Kitchen Range
The display on the oven does not work. As a result I can not operate the oven as you use the display to programme it.
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
The display has stopped working, the oven light works, the gas burners work.
There may be a fuse inside the oven which has failed or it could be the electronic display board.
Sep 18, 2015 | Ovens
Is there a way of re-setting the programmer?
Have you checked the oven fuse on the stove? And if the baking element is getting power?
Mar 25, 2015 | De Dietrich Ovens
Oven timer not working
Make sure you're using right programme. There is a countdown timer that does not affect the oven operation. This is the one with a bell on it. If you want to stop start then use other programmes.
Nov 10, 2013 | Zanussi Ovens
Error 08 on my hotpoint ovan workes for a bit then goes off and sayes error 0 8
HELLO.
The code displayed on the oven indicate that the oven has detected an error from the source of power control (panel).
This problem can be as a result of over flow of water or liquid substance on control unit,
or when there is over flow of power supply on the oven.
when the door of the oven is not properly close etc these can be as a result of the error code displayed on the screen of the oven.
WHAT YOU NEED TO DO TO SOLVE THE PROBLEM OF THE CODE DISPLAYED ON THE OVEN,
is to off and unplugged the oven from power supply for something then plug it and allow it to load on power on it's own before any form of operating then push the reset button if any.
With this the problem of the code will be solve
If there is a need for further help get back to me with your comment.
THANKS.
Sep 18, 2011 | Ovens
Grill works, but both ovens do not work.
Looking at the circuit diagram, it appears that there is a problem with the programmer. There is a contact that operates in it to provide power to both top and bottom ovens. The feed for the grill is prior to this contact, which explains why this is still working. Is the clock/programmmer set correctly? In some ovens, if the clock is not set then the ovens do not work. You should be able to hear the realy operating when the clock is set. If you need a copy of the handbook then if you supply an email address, I will send you a copy.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
HBN 56M5.1B oven and grill not working and no display. grill light does come on. tel 07944835691
hello mam please call the engineer and make him to check the programmer.and for loose connections.
Oct 04, 2009 | Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Parkinson Cowan SG556 Gas Kitchen Range Logo
19 people viewed this question
Top Parkinson Cowan Kitchen Ranges Experts
paulcarew
Shehu Pro
Shehu Pro
Tim Whalen
Are you a Parkinson Cowan Kitchen Range Expert? Answer questions, earn points and help others
