Question about Viking Refrigerators
I cleaned my refrigerator and now the lights don't work on either side of my side by side
  • Viking Master
  • 17,129 Answers
If your fridge is working without any complaint then it is possible that the door switch is defective due to some contact fault.
You can check the door switch contacts, check voltage to confirm.
If not trace to the power section/power circuit for loss of voltage.
Posted on Oct 09, 2010
I have a side by side frigidaire model PHS68EJSB0 and the display panel that shows the freeser and refrigerator temperature is not working and is not lighting up . also there is a beep every few seco
Sounds like a repair tech needs to diagnose the control board for a replacement. Make sure the temperatures inside are not increasing so you don't lose food items.
Sep 04, 2012 | Frigidaire Professional Series PHS68EJSB...
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
No light, no cooling in refrigerator, but cold freezer Americana A3316ABSDRWW
This usually means you have ice build up between the two units. Defrost the freezer and if possible let it sit to completely thaw all ice from the channels that allow cold air from the freezer to move to the Refrigerator side. You will also want to check your door seals to make sure you don't have any leaks or a bad seal causing your issue. The issue with the light is most likely a burned Bulb or bad switch. Replace the bulb and see if that resolves the issue. You also need to check and make sure the fans are working properly which move the air from the freezer to the refrigerator side and that all the cooling grill son the unit are clean and not clogged with dust build up.
Nov 25, 2011 | KitchenAid Refrigerators
GE SIDE BY SIDE (GSS25LGM)SERIAL#GD425395 LIGHT IS ON BUT DOESNOT GET COLD HOW TO FIX IT
Thanks for contacting Fixya.com
If you have a fridge with a working light, but no cold air, the first thing you should do is check the temperature setting to make sure it is set properly. Next, you will need to clean the refrigerator part known as the condenser coils. These are located on the back of the fridge, and these coils are a refrigerator part that gets very dirty. Cleaning them can restore lost efficiency, but you will need to disconnect the fridge first before cleaning this set of refrigerator parts. You should also insure that there is a three-inch dead space between the refrigerator and the walls near the unit.
Thank You
Sep 28, 2011 | GE GSS25LGM Side by Side Refrigerator
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Good afternoon, we just had our power turned back
Hi! I know this may sound weird, but you should try to wash it with vinegar, plain vinegar will do the trick. Also, I don't know if you have this in your country, but sour lemon it is good too, for this kind of situations.
After this treatment it is applied, wash it with a cleaning solution mixed with water, then rinse with simple water.
I hope this will help you! Have a nice day!
*please don't forget to rate my services :)
Sep 02, 2011 | Maytag MSD2736GR Side by Side Refrigerator
My refrigerator & freezer has stopped cooling. The lights are working, the fan runs, the coils are clean as well as no build-up of dust, etc. however, the condenser is not coming on...all I hear is a...
You have a compressor that is trying to start but is not able and is going off on overload. A tech can try a "hard start kit" if the compressor is still unable to start then don't spend any more on it, get a new fridge
Jun 22, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Blade in back of side by side not turning. Lights are on. Freezer not freezing & refrigerator not cooling. Cleaned out coils & the back area. No leakage on floor.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsjksfyj
Aug 17, 2009 | Amana ASD2326HE Side by Side Refrigerator
Frigidare
only 5 years is important, sounds very much like you have a bad compressor, It's trying to start asn cant so it shuts down(therees the noise your hearing. 5 year manufacture warr. so see if you can find your bill of sale. and give manufacture a call
Mar 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE Profile refrigerator side/side
i don think that would help solve your problem is your compressor running all the time there is a 1/8 in steel line coming from it is it hot or just warm where it goes into the back of the cabinet from the compressor and how old is the unit dont rate me till were done
Jan 13, 2008 | Refrigerators
Refrigerators Logo
90 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
