Question about Peavey PV® 900 360W Power Amplifier
How to disassemble Peavey Amp model PV-900 i just need to clean it cause one of the plug (1/4 or xlr) won't works correctly, i need to make a presseure on it to listen sound from one of our speakers! Thanks in advanced for your help!
    President:
  • 1,138 Answers
You will need to remove either the top or bottom panel to get at the jacks. There is probably a bad solder joint that needs to be repaired. You might try tightening the screws on the XLR jacks that fasten them to the back panel first and the nuts that fasten the 1/4"jacks also. I really do not recommend you do this yourself ( accessing the interior) unless you have electronic servicing experience as the filter capacitors in the power supply store a dangerous charge and are soldered to the circuit board in fairly close vicinity to the output stage.
Posted on Oct 23, 2010
How do I connect a peavey 32fx mixer to a peavey pv3800 ampflifier
You should be able to connect the XLR l&r outputs to the amp or the 1/4" l&r outs to the amp. Check out the manual here.
http://assets.peavey.com/literature/manuals/FX_Mixers.pdf http://assets.peavey.com/literature/manuals/FX_Mixers.pdf
Nov 03, 2015 | Peavey Music
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
Power problems with my Peavey PV-1500
Suspect that the pot is broken, or start cleaning all the back switches, this pv amps suffer from a terrible switch quality.
Mar 15, 2012 | Peavey Electronics Peavey Pv 1500 Power...
Which amp input connects to the mixer?
That would be the two black combo 1/4" and XLR
Jul 08, 2011 | Peavey Pv 2600 Power Amplifier
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
I feel like a dork asking this question but how do you connect the amplifier to your mixer. I see that there are places for a banna plug however my mixer will not take a 1/4 banna plug.
In case you don't have one, here is a link to the manual:http://www.peavey.com/assets/literature/manuals/80300573.pdf I don't know if you are using a separate crossover between the mixer and the amp but here is the simplest explanation.I just reread your question and I don't even know whether you have a Peavey amp. Run proper cables from the main output of your mixer to the main inputs of your power amp.They will be 1/4"shielded cables or Balanced XLR cables. Do not use unshielded speaker cables to hook the mixer and the amp together.Run speaker cables from the speaker outputs of the amp to the input jacks of your speakers.Make sure the impedance of your speaker cabinets equals or exceeds the impedance rating marked on your amp. Here is the link to the newer model PV2600 manual:http://www.sweetwater.com/store/media/pv2600_doc_manual.pdf Don't use Speakon cables unless your speaker cabinets are equipped with Speakon input jacks. Banana plugs aren't as solid a connection as the binding posts are.
Nov 07, 2010 | Peavey Pv 2600 Power Amplifier
All resistors are burnt ineed the part numbers for Pvy .model 2600
Send me your email with subject Peavey and I will send PDF of schematics, etc.
Aug 11, 2010 | Peavey PV® 900 360W Power Amplifier
I have 2 peavey 900 Power Amplifiers i would like to link them together was wondering what is the input wattage it can handle?? not wanting to mess anything up!
You CANNOT link the outputs of the amps. They need to drive seperate speakers.
You can tie the inputs together so they will send the same sound to their seperate speakers.
Max power for the Peavey 900 is 900 Watts RMS into a 4 ohm speaker in Bridge mode... That is enough to blow many speakers.
May 15, 2010 | Peavey Pv 2600 Power Amplifier
Peavey PV® 900 360W Power Amplifier Logo
212 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
