Question about Maytag Refrigerators
Every 3 minutes the fridge makes a loud buzzing sound. seems to come from compressor.lasts about 10 seconds then stops with a click
  • judcro Jun 02, 2008
    Haven't had a chance to try it yet. The part had to be ordered & hasn't come in yet. Will let you know if it worked,
  • judcro Jun 05, 2008
    Part installed last night. Fridge seems to have cooled down overnight & appears to be working properly.
  • 770 Answers
Your start system for the compresser (relay and overload) is out you will need to replace go to to look it up by your model number
Posted on May 30, 2008
  • Gary Davd
    Gary Davd Jun 02, 2008
    let me know Thanks
Have an LG fridge about 10 years old... makes a loud buzzing noise occasionally. Fridge seem to be running fine.. Thoughts??
Dear Sir
I think this abnormal buzzing sound coming from you
Compressor inside thats creating the buzzi sounds its normal. After a long time used it can possible. Neednt to worry
Hope answer the question
Jul 19, 2016 | LG Refrigerators
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
These will help.
Dec 22, 2012 | Refrigerators
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
Feb 05, 2010 | Refrigerators
Maytag fridge stops cooling, then 1-2 days later restarts on own
The buzzing is typically gonna be the compressor trying to start and failing. Am I right in saying the fridge is at least 12 or more years old?
Maytag used to use a compressor made by Tecumseh and they had a problem with starting. They would buzz and sometimes start back up. Sometimes in a few tries or a few days or never. It would continue to re try every couple minutes and last 5-10 seconds.
I would verify if it is a Tecumseh or an Embraco compressor then make your decision.
A service tech should be able to figure this out pretty easily! Normally what I would do is if I go in and it is running then I would turn it off and back on right away. the fridge will go through its restart sequence and typically make its noises then. Hopefully you are not being charged every time they come out
Compressors are the most expensive repair! and on these I always replace the discharge tube since they tend to rot out from sitting in the drain pan.
Let us know what you find!
Feb 21, 2018 | Maytag MFD2561HE Bottom Freezer French...
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Buzzing sound
the buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
Dec 05, 2007 | Amana ATB1935HR Top Freezer Refrigerator
Refrigerators Logo
140 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
