Question about Moen Two-handle Bathroom Sink Faucet With Drain Assembly
Just installed a new Moen bath faucet, CA84912, and there is only a 'trickle' of water coming out when cold handle is opened. The hot side has much more discharge flow. Is this due to a restrictor to limit flow? If so, can it be removed to get better flow?
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Posted on Feb 26, 2009
  • 129 Answers
SOURCE: Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Posted on Oct 10, 2009
motor1258
  • 6674 Answers
SOURCE: Cold water flow is slow and handle is starting to
Not sure whether you are aware or not but most times, if you call moen with your model number and explain the problem your having, they will usually send you (free of charge-lifetime warranty) the part with instructions on repairing it along with it. You may have the 7800 series, but there are 3 or 4 different models if you check their site, and can identify the actual model, they will send you repair parts. Tell them you bought it ? years ago, and don't have the receipt, if they even ask.
try this link, if no luck, get back to me.
http://www.moen.com/replacement-parts
Posted on Apr 17, 2010
SOURCE: Loose handle on my Moen single handle kitchen faucet
I had a similar problem. After a few weeks the lever began to "tighten up". It began first with the hot water at full flow and progressed over a couple of weeks to full control.
Posted on Oct 28, 2010
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
I just put in a Moen single, chrome handle shower faucet in my hall bath. Got it all together and the hot water is not comming out. Cold water is fine, but, when i turn the handle to the position where the...
If this is a Moen posi temp valve you may need to adjust the temperature limit stop. It is located under the handle. Usualy a plastic peice with grooves in it so it fits in another peice in the valve. If I remember right you pull this peice out and turn it counter clockwise to get more hot water. Do this in small increments and reassemble and test. I hope this helps.
May 25, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Turn hot handle on - water does not come out of faucet
is the feed on the bottom of the sink open . if it is shut the water off from the bottom and take apart the handle to see if something is stuck in there
Sep 26, 2009 | Moen 4551___ Monticello Popular Two Handle...
I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
No hot water
turm off the water at the main first.
take the handle and the plate off the control.
use a plier to take out the cartridge.
replace with a new one or you can repair by change all of the "O" rings and rubber sets.
make sure the postion when you take off the cartridge. there is front and back to the cartridge. if you install it backwards, it will not work.
Dec 04, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen Two-handle Bathroom Sink Faucet With Drain Assembly Logo
102 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
